-31 actuator
Old Mar 30, 2010 | 07:15 PM
ROB7656's Avatar
ROB7656
Default -31 actuator
what is there boost range?
Old Mar 30, 2010 | 07:52 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
MSD suggested set it to 10psi and bleed off another 10psi.
so a combined total of 20psi, using whatever bleed device you wish, i use a gizzmo IBC.
you can of course go a little more, i'm on a collins actuator with new spring fitted and it hits 14psi without the need for bleeding off.
Old Mar 30, 2010 | 07:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah mine is set to about 10psi and i will be bleeding off at least another 11psi.... in fact i'll probably set mine to about 14psi and be bleeding off another 11psi! lol
Old Mar 30, 2010 | 09:02 PM
ROB7656's Avatar
ROB7656
ok . my car is standard but i have bought a -31 and turbo system ecu i was going to run it at 7 psi until my new clutch is in.
will a -31 do 7psi? if not i just wont let it boost as my fueling was set last year for 7 psi?
will be getting it tuned to run a bar as soon as the new clutch is in
Old Mar 31, 2010 | 06:24 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you can drop some preload to lower the boost level, but likely to spike more.
Old Mar 31, 2010 | 08:02 PM
ROB7656's Avatar
ROB7656
i will keep a close eye on the boost gauge! only got to drive 15 miles to my tuner so im sure i can retain myself.... cheers
Old Mar 31, 2010 | 08:06 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i live a mile and a half from work, so i warm engine up, then thrash it to work
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
