Dead wated spark driver !
The loom im using has nothing to do with the original coil still attached ( apart from the ignition amp ) and im using an MSD wasted spark loom, so there is no suppressors etc on the loom.
Any other ideas ?
I will have a chat with MSD in the week just wanted to try and find the cause this weekend whilst the weather was good
the amount of black smoke that was coming out of the exhaust made me not want to try. + its not tax'd as i was hoping to get it back on the road for the start of April
Another odd thing, which may be related to the W/S driver, with th ignition turn on, a spark plug in the lead and earth'd ( to see if a spark ) its like its sparking rapidly but the small sparks are just arcing to the side of the plug. Now, same situation ignition on, if i unplug the coilpack and then plug it back in again, the small rapid sparking stops.
Im confused.
Ive just taken the loom out and tested it and it all seems fine ( althogh i cant get the IAW to work on it ). Can MSD test looms ?
Im confused.
Yeah it will work without it provided the fault that caused that doesnt affect anything else.
"JESUS" because the only real way to get that device damaged like that is to short the rev counter output of the module to 12 volts positive somehow !
That device probably saw a peak curremt of around 400 amps for a few milliseconds..LOL
Thank you again Simon.
Thats something for me to look at then as the mainloom connector isnt even plugged in. Just the ignition switch.
Any idea on the interference type thing on the sparking ?
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
deathrider666
Sep 28, 2015 06:12 PM
