Merc Sprinter problem.
Old Mar 28, 2010 | 11:03 AM
cheftony1's Avatar
cheftony1
Default Merc Sprinter problem.
Any bods on here maybe point me in the right direction with a bit of a problem on my Sprinter.
Occasinally (usually going up a certian slip road onto motorway uphill) The engind decides to not rev past about 3,000 revs or about 45-50 MPH. Almost like it`s in a safety mode.
It`s happened on this same road three times now, and at other places.
It goes on like this until I pull up at work and switch off, then seems ok again.
Anybody have any ideas.
cheers
Tony
Old Mar 28, 2010 | 11:07 AM
focusv8's Avatar
focusv8
Something stupid like Low Oil or low Water putting it into Limp?
Old Mar 28, 2010 | 11:11 AM
steve4i's Avatar
steve4i
either check the switch on the clutch pedal or you havent put you foot slightly ont eh clutch pedal have you?
Old Mar 28, 2010 | 11:34 AM
Frogford's Avatar
Frogford
do they have ejr (sp?) valves ? I know they can cause variouss vans to throw a hissy fit ?
Old Mar 28, 2010 | 11:39 AM
focusv8's Avatar
focusv8
Originally Posted by Frogford
do they have ejr (sp?) valves ? I know they can cause various vans to throw a pissy fit ?
EGR = Exhaust Gas recirc.
Old Mar 28, 2010 | 12:34 PM
dazzabhoy's Avatar
dazzabhoy
there is a vaccum sensor under the airbox check that, also check the map sensor
Old Mar 28, 2010 | 01:52 PM
DazC's Avatar
DazC
This is the way forward.
There is a vacuum solenoid valve under the airbox that controls the turbo boost pressure. They usually go fucked causing loss of power.
Give the clutch switch a visual inspection. Make sure it's not loose.
Old Mar 28, 2010 | 06:26 PM
Big G's Avatar
Big G
Had a problem like this on a 51 plate at a place I worked at, annoyingly intermittent that usually showed a clear when the mechanic plugs his computer in, It turned out to be a 10 bob sensor on the nearside of the engine, just a fucking nuisance to diagnose.
dojj
Sep 29, 2015 10:32 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
Ebonycossie4x4
15
Sep 2, 2015 11:40 PM
Sheepdisease
Aug 30, 2015 09:11 PM
