Will this box fit
Will this gear box fit onto a coworth motor . the bell houseing looks in the same place to me
GEARBOX FROM A 1991 J REG 2.0 SIERRA XR4X4
or this one
Sierra 4x4 gearbox . come off a 2.9 v6
or this one
The DOHC 4x4 gearbox is identical to the Cosworth box in every way - Bearings, shaft sizes, bellhousing, inputshaft etc etc.
The only difference between it and the Cosworth 4x4 box is the Cosworth box has an oil flicker on the 5th gear layshaft - Not a problem, I used a DOHC box in my 350bhp Cossie after popping 3rd gear of the Cosworth box
The V6 box wonh't fit as the bell housing is different and the input shaft is longer.
matman
Sep 9, 2015 05:45 PM
