Xr3i mk4 really fast idle, like 4000rpm
Old Mar 27, 2010 | 07:22 PM
Kammer111's Avatar
Kammer111
Default Xr3i mk4 really fast idle, like 4000rpm
Hi guys. I have just changed the head gasket on my 1.6 cvh and turned the key for the first time the other day and it idles at 3500-4000rpm! Obviously this is not normal. Checked all the hoses and are fine. Any other ideas to try?
Any help appreciated.
Old Mar 27, 2010 | 07:25 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
erm timing, vacume pipes, did ya change the cam belt
Old Mar 27, 2010 | 07:26 PM
botters's Avatar
botters
competant bodger
sounds like a big air leak somewhere inlet manifold gasket or throttle gasket perhaps?
Old Mar 27, 2010 | 07:28 PM
Kammer111's Avatar
Kammer111
Timing is the same as when I took off the head but didn't change the belt.
Old Mar 27, 2010 | 07:31 PM
Kammer111's Avatar
Kammer111
Ah well, I didn't put the thottle gasket back on because it was ripped and didn't have a new one. Wouldn't have thought that it would let that much air in though.
Old Mar 27, 2010 | 07:32 PM
gingerturbo
ok did ya removed the inlet at all
Old Mar 27, 2010 | 07:33 PM
gingerturbo
there ya go problem solved well done
botters's Avatar
botters
competant bodger
it most certainly will mate get a new one on and you will be sorted, also put a new cambelt on you should NEVER re use a timing belt no matter how new it is as it WILL snap
Old Mar 27, 2010 | 07:36 PM
Kammer111's Avatar
Kammer111
I did take the inlet off and put a new gasket on it but not on the throtle. That wouldn't let enough air in to make it idle at 4000rmp
Old Mar 27, 2010 | 07:42 PM
botters's Avatar
botters
competant bodger
oh yes it will mate been there seen it done it
Old Mar 27, 2010 | 07:43 PM
Kammer111's Avatar
Kammer111
It's an efi inlet btw
Old Mar 27, 2010 | 07:44 PM
bigjono's Avatar
bigjono
anyair leak will cause an air surge, ecu will alter mixture to compensate, fit a new gasket and u be fine
Old Mar 27, 2010 | 07:45 PM
botters's Avatar
botters
competant bodger
makes no difference whether its efi or mfi mate having no gasket on the throttle will cause it to suck in massive amounts of air regardless you dont need a big gap for lots of air to get through
Old Mar 27, 2010 | 07:46 PM
Kammer111's Avatar
Kammer111
Ok thanks
Old Mar 27, 2010 | 08:38 PM
You'd be amazed how little air is needed for idling on no load.
Old Mar 27, 2010 | 08:39 PM
martysmartie's Avatar
martysmartie
You have answered your own question this without doubt is whats causing the problem, timing will have no effect on engine speed, also as said get a timing belt and tentioner never reuse one you have taken off, not worth the risk!
Martin
Old Mar 27, 2010 | 08:49 PM
Kammer111's Avatar
Kammer111
Ok. Thanks for the info guys. Much appreciated
Old Apr 16, 2010 | 10:31 AM
Animall98's Avatar
Animall98
Born Again Boy Racer
Default throttle gasket-efi 1600 escort
i having this problem after engine rebulid-is it the inlet manifold gasket cos i fitted a new one-cant see where throttle gasket is
stephenb4506
33
Oct 2, 2015 06:25 PM
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
