Help please no spark ! grrr s1 turbo
Old Mar 27, 2010 | 06:39 PM
searlesy's Avatar
searlesy
Question Help please no spark ! grrr s1 turbo
I have an rsturbo s1 i had it started few months ago since ive changed inlet manifold and alternater now im getting no nspark its driving me nutz can anyone help please
Old Mar 27, 2010 | 07:16 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
have ya put the earth back on the inlet, and have ya checked everything is wired up
Old Mar 27, 2010 | 07:23 PM
searlesy's Avatar
searlesy
Yeah done that mate got power coming out of the coil just no spark, im pulling my hair out with it
Old Mar 27, 2010 | 07:27 PM
gingerturbo
have ya got a new dizzy cap and rotor arm
Old Mar 27, 2010 | 07:50 PM
searlesy's Avatar
searlesy
Yeah mate ? its got me completely stuckk
Old Mar 27, 2010 | 07:52 PM
gingerturbo
right have ya got spark coming from the ht leads
Old Mar 27, 2010 | 07:54 PM
searlesy's Avatar
searlesy
No mate
Old Mar 27, 2010 | 07:56 PM
gingerturbo
what leads are they and are they on the right way i.e 1-4-3-2
Old Mar 27, 2010 | 08:00 PM
searlesy's Avatar
searlesy
yeah mate was running fine b4 i done the work
Old Mar 27, 2010 | 08:05 PM
gingerturbo
is it mfi or efi, and i take it all the loom is plugged in?????? when did ya change the dizzy cap
Old Mar 27, 2010 | 08:18 PM
steve4i's Avatar
steve4i
might be the condenser on the dizzy try swapping it over
Old Mar 27, 2010 | 08:20 PM
martysmartie's Avatar
martysmartie
Presumably when you say coil power is ok you mean from the king lead not the supply voltage to it as that means nothing. Should have healthy spark from king lead. If not theres no point opening up dizzy, checking HT leads etc.
Check the dizzy cap for cracks despite it being NEW.
Martin
Old Mar 27, 2010 | 08:25 PM
searlesy's Avatar
searlesy
Its mfi yeah n everything slse plugged in n changed dizzy cap n rotor arm wednesday ,dont know if this makes any sense to you but the plug on side of dizzy shows pos-12v 0=4 1/2v neg=0v but when i take off small earth i get 12v on all ???? also tried direct earth from battery to coil n nuffin then tried live n nuffin been trying for past 2 weeks its driving me nutz
Old Mar 27, 2010 | 08:28 PM
searlesy's Avatar
searlesy
when i take ht lead from dizzy that goes to the coil ive got good power but when i put it to a earth it doent spark
Old Mar 27, 2010 | 08:40 PM
gingerturbo
where do ya try to earth it to i.e engine/body and where did ya get ya dizzy cap from, does sound like either an earth problem or ya dizzy
Old Mar 27, 2010 | 08:41 PM
martysmartie
Thats the LT (King lead) what do you mean by you have good power? When this lead is earthed (On good earth not a painted surface, rather likes of unpainted bolt head etc) and engine turned over you should have a spark if not this will be your problem.
Martin
Old Mar 27, 2010 | 09:01 PM
searlesy's Avatar
searlesy
tested with electric voltage meter and got good voltageking led to engine lift eye and turned it over and theres no spark and then put it to battery terminal and no spark
Old Mar 27, 2010 | 09:08 PM
martysmartie
You won't have any voltage at king lead unless engine turned over and this will be thousands of volts which your voltmeter woulden't be able to read, I think the plug on side of dizzy you talk about is for the electronic module (Effectively an electronic switch for coil)
You should have +12V to coil one side and the other is switched by above method it's actually when the earth is broken you have power at king lead due to voltage collapse inside coil.
Depending where in Dartford you are I may be able to help you?
Martin
Old Mar 27, 2010 | 09:16 PM
searlesy's Avatar
searlesy
I'm in real need of some help im at da1 5jr i would really be grateful for any help
Thanks Chris
Old Mar 27, 2010 | 09:25 PM
martysmartie
Another thing to check is the green wire from the coil as these break.
Martin
Old Mar 27, 2010 | 09:36 PM
searlesy's Avatar
searlesy
thats alredy bin replaced and checked
Old Mar 28, 2010 | 08:47 AM
gingerturbo
it might be ya lead from the coil to the dizzy as they can break up inside, are they magnicore leads
Old Mar 28, 2010 | 08:48 AM
gingerturbo
Thanks Chris
have ya tried racepower just down the road from ya
Old Mar 28, 2010 | 10:16 AM
searlesy's Avatar
searlesy
is that in borough green ?
Old Mar 28, 2010 | 10:22 AM
martysmartie
In that case I reccon the inducive module in the dizzy is faulty or the wiring to/on it or even the coil itself.
Martin
Old Mar 28, 2010 | 03:21 PM
gingerturbo
nah its in swanscombe just past mac,d's
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
adriansaleem
Aug 1, 2015 09:28 PM
