mk1 3 door heated rear screen and washer jet not working
Old Mar 27, 2010 | 05:26 PM
boy-racer-1's Avatar
boy-racer-1
Default mk1 3 door heated rear screen and washer jet not working
ok ive got a mk1 3 door sierra and found out over christmas that the heated rear screen didnt work and neither did the washer jet which is built into the wiper arm (well im guessing as thats what it looks like) im assuming its not an earth being that the wiper still works, and was wondering if theres a common fault with these? or if anyone knows how i can fix it? as i have no idea where to start, the button for the heated rear screen works fine and changes colour light when on, but doesnt actually heat up the rear screen
Old Mar 27, 2010 | 08:09 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
have ya checked the little loom that goes from the shell to the boot as they wear due to being opened and closed a lot
Old Mar 27, 2010 | 08:30 PM
The two problems are not related.
Can you hear the washer pump run ?, may have frozen over cold months and blown the fuse when trying it ?
The HRS, the wires always break inside the insulation,(esp on mk4 escorts!!), so a good probe with a test light, first at the connections on the screen for the live, chances are it is broken inside the insulation from constant opening/shutting movement, but easy fix, just use some heatshrink to seal the wire after fixing instead of tape if you can.
Old Mar 28, 2010 | 05:29 PM
boy-racer-1
cant hear any pump run atall, ill check the fuses tomorow and also the wires
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
