how 2 start a cosworth
Old Mar 26, 2010 | 10:41 PM
new1's Avatar
new1
Default how 2 start a cosworth
hi i just got a sierra cosworth on a (e reg the car not been started 4 3 years wot is the best way 2 get it started??... can i put petrol down the turbo?
Old Mar 26, 2010 | 10:43 PM
botters's Avatar
botters
competant bodger
put a battery on and turn the key!
Old Mar 26, 2010 | 10:47 PM
new1's Avatar
new1
yea i done that all ready not starting up any think els i can do
Old Mar 26, 2010 | 10:49 PM
james kiely's Avatar
james kiely
needle in a haystack mate ,could be a multitude of stuff.is it turning over ,have you petrol at the fuel rail?
Old Mar 26, 2010 | 10:50 PM
m4tt274's Avatar
m4tt274
if it not starting probably sumit wrong. check all the connectors. check the fuel pump. check ..... anything and everything tbh. may have no plugs under the leads, could be anything
Old Mar 26, 2010 | 10:55 PM
new1's Avatar
new1
yea its turning over but not starting. cant i put petrol down the pistons 2 see if it wil start thanks
Old Mar 26, 2010 | 10:59 PM
james kiely
not really no
sounds like you need to get it to someone who knows their stuff mate ,also might be worth checking/changing the timing belt to be on the safe side
Old Mar 26, 2010 | 11:03 PM
jerh20's Avatar
jerh20
Try putting some fresh fuel in. After 3 years its prob 'dead'. If theres alot of old fuel in the tank u prob need to drain it. If i was u i certainly would not put fuel straight into the cylinders.God only knows what u could damage.
Old Mar 27, 2010 | 07:53 AM
AS said don't pour fuel down the plug holes, only likely result will be wet plugs, or if too much fuel hydraulic lock and wrecked engine.
Firstly make sure the oil light goes out under cranking, make sure everything is connected, make sure plugs are ok and sparking.
Can detach intercooler to throttle housing pipe and spray a LITTLE easy start in there as turning over(need assistant here), if sparking it will fire, once up to temp drain/replace oil, filter coolant, fuel filter, drain replace fuel also.
Old Mar 27, 2010 | 11:43 AM
LHD220Turbo's Avatar
LHD220Turbo
a can of easy start helped mine start
Old Mar 27, 2010 | 01:08 PM
cossied-down's Avatar
cossied-down
Get an old haines Sierra WORKSHOP MANUAL pennys on ebay (the new ones arn't so informative or good) they explain electronic ignition sytems and the fuel system very well with fault finding, cheap and cheerful I've saved thousands over the years
Old Apr 1, 2010 | 02:49 PM
martynhomer01's Avatar
martynhomer01
tow it behind something fast and turn the ignition on and dump the clutch in 3rd.....lol
seriously tho................double check all the oil pressure and fuel rails etc as explained. do not try and rush to start her...............they are like good women..... a little fettling and attention here and there, and then all of a sudden she will turn on when she is good and ready.
good luck matey
Old Apr 1, 2010 | 02:51 PM
cossiejay's Avatar
cossiejay
get someone who knows what they are doing to have a look
Old Apr 1, 2010 | 03:00 PM
martynhomer01
is it a 3dr or saph?
Old Apr 1, 2010 | 03:01 PM
rog's Avatar
rog
Probably too late now, but you don't want to start it without being too cautious first. I'd take of the coil lead and crank it over till the oil light goes out, then connect it back up, that way you know you'll have good oil pressure and the engine won't instantly start from o to 900 rpm after 4 years with no oil.
But I'd defo take it to a specialist, but if your hell bent on doing it yourself i'd change the plugs, which cost about a tenner, and drain the fuel, or dilute with alot of new fuel if the level is low enough. It SHOULD start if there isn't a problem elsewhere.
Your probably better off putting up a post on here asking if there is anyone local to you who can have a look, for free, and without sounding too much of a twat it doesn't really seem that you know where to start, so you've nothing to lose really.
Old Apr 5, 2010 | 10:59 PM
new1's Avatar
new1
hi guys i cant get it 2 go some think rong with the loom i think i mite aswel just sell it as i got some think new 2 work on thanks
Old Apr 6, 2010 | 08:04 AM
LHD220Turbo
if your going to give up that quickly i dont think cosworth ownership is for you
Old Apr 6, 2010 | 09:14 AM
bythomson's Avatar
bythomson
what a pointless thread . you shouldnt be near a ford if thats your attitude, people offered some assisstance and you feck them off and say oh ill just punt it ..... twat
Old Apr 6, 2010 | 10:23 AM
opposite lock's Avatar
opposite lock
yep this must be the quickest quit on passionford ever lmao . Its 20 years old mate dont expect it to be all hunky dorry good luck with ur new project u may need it!
Old Apr 6, 2010 | 10:36 AM
danzul's Avatar
danzul
ohhhhh dear........,
Old Apr 6, 2010 | 12:37 PM
johnenright150rst's Avatar
johnenright150rst
Jesus Christ, I have a mate that is the same got a fez turbo for a bargin of 700 quid needs a little help, been giving up time I could have spending on my two rs turbos.
Then he phones me saying it's smoking , to whick I reply it could be your turbo .(frst t2) then he replys " fuck it I gonna sell the unreliable piece of shit!
He's only had It 2/3 weeks!!
if you want a boring reliable car buy somthing new! Not 20years old.
Old Apr 6, 2010 | 03:44 PM
jerh20's Avatar
jerh20
I'll give ya 200 quid for it LOL!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 6, 2010 | 04:22 PM
4x4 S2 Cossie's Avatar
4x4 S2 Cossie
I rescued a 2wd saph that had been stood for abt the same sort of time. Thought it would be all hunky dory (my first cossie actually) but oh no......rings gone, overheating, calipers seized, floorpan gone in 4 places and so on. But it was so worth it; the satisfaction you get when shes all up and running!! Plus you learn so much by doing so! To me, that's all part of the fun being a cossie owner! Hope you don't lose heart to quick mate.
Cheers, Chris
Aug 14, 2015 07:29 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
