cosworth idle speed control valve ??????
Yes or no.............. as i no the one on my car and my mates are playing up so need some one one and would like to now if there any good for cosworth i no it says they are but wot do you think
http://cgi.ebay.co.uk/Idle-control-v...item2558a6bda2
have you tried taking yours off and cleaning it? worked a treat on mine i was suffering from lumpy cold running and revs sticking on when running so valve was obviously seized so cleaned it with brake cleaner got the valve moving again and its sorted job jobbed!
Take yours to bits properly, remove the nut off the bottom of the shaft, and clean the valve and inside etc. It will work perfectly. Just remember which order the 2 springs go in, and put some locktite on the end of the nut after
JoeyBoyden
Aug 18, 2015 05:56 PM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
