Cheapest AP Brake Supplier
Old Mar 24, 2010 | 05:53 PM
cossie2be's Avatar
cossie2be
Default Cheapest AP Brake Supplier
Who is the cheapest, 2K has been my cheapest so far for 355/360mm AP's
Jeff
Old Mar 24, 2010 | 05:57 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
what application ,
2wd - 4x4 , ?
iirc , from a post recently , reyland doe a 355 6 pot kit for around the 1750 mark
dont quote me though not sure if that was with vat or not ,
beef
good question though !!!
Old Mar 24, 2010 | 07:33 PM
Turbosimpsons's Avatar
Turbosimpsons
i got mine through Turbosystems.
Old Mar 24, 2010 | 07:38 PM
KSA-Cossie's Avatar
KSA-Cossie
Rainbum or reyland.
Old Mar 24, 2010 | 07:56 PM
Touring Car Spares's Avatar
Touring Car Spares
Depending what you want/need , we can supply a kit that uses our good supply of used WTCC 332mm x32mm Cross drilled Brake discs ,we spin up bells to make up the floating kit and can make brackets to suit as well ,you will need to have Calipers that accept a 32mm disc tho and 2 x sets of brake bobbins this may push your budget .
stephenb4506
33
Oct 2, 2015 06:25 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
