Correct Offset
The OEM rims on the Sapphire are 7Jx15H2E40; meaning a 40 mm offset.
What is the correct offset if you go to 8x16 or 8x17 inch rims.
I am thinking Revolution Millenniums, Compomotive 1781 or Speedline 2108.
Thanks
Thanks
I know lots of people use Escos alloys on their Sapphires but I thought they weren't 'quite' the right offset for a 4-door ( although I realize the Escos is based on a 4x4 Saph ).
Is there any chance of arch interference or is that only with excessive lowering or is there some unfavourable geometry steer issues involved as well?
I would say ET35 and was advised to use this offset off Martin at Reyland, had this offset on my 8x17, and now on 8x18.
Revolution Milleniums run a GrpA offset of Et30.
Thanks for the replies. There seems to be many people using ET32 to 35. I guess if there are no problems wit arch interference then that is the way to go,
According to the calculator:
An 8 inch rim with 32 mm offset reduces the inner clearance by 5 mm and extends the outside edge of the wheel an extra 21 mm.
An 8 inch rim with 25 mm offset gives 2 mm of extra clearance on the inside and extends the outer edge of the wheel an extra 28 mm.
I haven't looked at the car and measured; but it seems to me that the 25 mm offset on 8 inch rims might well be problematic. A 28 mm extension of the outer edge of the wheel is a lot.
The 32 mm offset seems more likely to work but I really, really, really don't want any fouling of the arch.
Is anyone running 8 x 17 ET 32 rims having issues with fouling; either inside or on the arch?
with the standard rims, how much clearance is there on the inside, and how much room do you have to play with on the outside?
Very useful little tool.
https://passionford.com/forum/techni...-sapphire.html
Mike1
Gonna use 225/45 with the 16's, Kumho or Toyo track tyres
Would have prefered 225/40, but don't seem to be able to get them in 16's
BJAS
8x17 with 225/35 were OK on mine, though i did ease the front arches a little on the inner lip. BUT it is purely dependant on the tyre size and ride height you have. And the age of springs as they will sag with time and run lower.
BJAS
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
