Cosworth management conversion problem
Old Mar 23, 2010 | 06:58 PM
studabear's Avatar
studabear
Default Cosworth management conversion problem
I've coverted from mfi to efi on a rs turbo engine using cosworth gear
L6 ecu and wasted spark driver all new sensors, only used parts are coil pack and ignition modules
I'm having the problem that the injectors are not pulsing and I'm not getting spark
All sensor air gaps are at 6thou and afaik aligned correctly
My question is if 1 of the ignition amps or coil was faulty would this stop the injectors pulsing?
As we may be removing the wasted spark driver set up to revert to the distributor as I know my ecu worked that way
Or am I barking up the wrong tree
Old Mar 24, 2010 | 01:10 PM
A non read from the crank sensor will lose both fuel and ignition so check this first, a gap of around 0.8mm will be fine, it's not critical, I would also check you defo getting power to ecu first ?
The 12v LIVE for the injectors simply comes from a relay when ecu powers up, so check to see if you have a permanent live at each injector.
Old Mar 24, 2010 | 06:50 PM
studabear's Avatar
studabear
cheers tab will check it out, sure ecu is coming on as when the engine is turned over by hand the fuel pump cuts in (ignition on)
Old Apr 2, 2010 | 01:08 PM
studabear's Avatar
studabear
Found a wiring problem
When I cut back the old coil connections I didn't rejoin the feed for live to ignition modules, thats all sorted now so once my ecu comes back from testing I will hopefully get it running
Would the ecu sense no ignition and stop the injectors pulsing???
Old Apr 2, 2010 | 01:27 PM
martysmartie's Avatar
martysmartie
No, CPS could, it's the Phase sensor that provides the info for sequential fuel injection.
Martin
CLIVE
Oct 2, 2015 12:58 PM
jay030787
Sep 18, 2015 07:34 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
