What to do next mod?
Old Mar 23, 2010 | 03:29 PM
Xr2iTurbo's Avatar
Xr2iTurbo
Default What to do next mod?
A bit of advice whats the next step for tuning? 1.6 efi turbo,its got a ported and polished head,piper 285t2 cam,beige injectors, stg 2 chip,uprated fuel pump,front mount intercooler,-31 actuator turbo been re built with t28 internals and just had the full inlet,throttle body and cross over gas flowed too.what should i do next for a bit more power? Any replys much appreciated
Old Mar 23, 2010 | 03:32 PM
rs-tuner's Avatar
rs-tuner
Aftermarket management then more boost if the internals will take it
Old Mar 23, 2010 | 03:35 PM
turbo_3dr_tommy's Avatar
turbo_3dr_tommy
decent brakes lol
Old Mar 23, 2010 | 03:39 PM
Xr2iTurbo's Avatar
Xr2iTurbo
its a standard bottom end and its running a spacer plate from ferriday engineering not sure how much it will cope with its about 15psi at the moment,the engine is in good condition though its only got 30k miles on it,i wish when i bought it yrs ago id strengthend the bottom end a bit and put better pistons in,what sort of price would different management be fitted? Been looking at motorsport developments site they list a type of stg 3 chip would this be of any use to me do you think?
Old Mar 23, 2010 | 03:44 PM
rs-tuner's Avatar
rs-tuner
Go for new pistons and rods first then and get rid of the spacer plate
Old Mar 23, 2010 | 03:51 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
as abive then maybe get it live mapped at msd ?
Old Mar 23, 2010 | 03:54 PM
jonny s2's Avatar
jonny s2
is this a xr2i engine with a decomp plate?? firstly i wouldnt push it over the 15psi your running if it is,
what power are you looking for?
what are you wanting out of the car?
Old Mar 23, 2010 | 03:55 PM
Xr2iTurbo's Avatar
Xr2iTurbo
I think thats the route ill take when it all goes bang i just wanna see if there is any more to be had from it while its an this spec,its not my daily so if it breaks it can be repaired when needed
Old Mar 23, 2010 | 04:06 PM
Oranoco's Avatar
Oranoco
New rods and pistons, change the cam for a Newman item, T3 turbo and Escort RST manifold, aftermarket management with bigger injectors.
All imho of course
Old Mar 23, 2010 | 04:09 PM
Xr2iTurbo's Avatar
Xr2iTurbo
its a proper rts engine mate not a 2i engine thats been turbo'd im not realy sure what i want from it just a little bit more as last summer a red top corsa pulled past me at nearly 100 and i couldnt do anythin:-(it was embarrasing it does go well but jus want a little more,ive had my injectors cleaned and the gas flowed parts to go back on.a live map sounds good what does it actualy involve doing please
Old Mar 23, 2010 | 04:11 PM
jonny s2's Avatar
jonny s2
standard rods are only rated at 250hp at most and some brake below this figure, if your starting from scratch you wont go far wrong taking oranoco's advise
Old Mar 23, 2010 | 04:15 PM
Xr2iTurbo's Avatar
Xr2iTurbo
Old Mar 23, 2010 | 04:18 PM
jonny s2's Avatar
jonny s2
a live map involves taking it to the tuner and he would map on the road
how many miles has your engine done? strap a stage 3 t3 turbo on paddle clutch,make sure you have at least a big bearing gearbox, front mount cooler,take it to a tuner and get some bigger injectors, i reckon you could see 240+
Old Mar 23, 2010 | 04:30 PM
Xr2iTurbo's Avatar
Xr2iTurbo
if i could get to 230 or just over id be very happy,has any one had one of these live mapped?what should i expect from having this done,as th car is now its quite laggy i think when not on boost could a live map make it a little more driveable as its only realy much good when the revs are high
Old Mar 23, 2010 | 04:34 PM
jonny s2's Avatar
jonny s2
that would be down to low compression??
what is the compression ratio now??
Old Mar 23, 2010 | 04:44 PM
Xr2iTurbo's Avatar
Xr2iTurbo
thanks for explaining that i think my car could do with a live mappin session,hopefully it wil make it a bit more driveable.the engine is in excellent condition,would i need igger than beige injectors? Ive got a paddle clutch in already but still running standard 2i box so dont think it will last long although it was fine all last summer and i did a few hard launches so il keep fingers crossed for now on that
Old Mar 23, 2010 | 04:59 PM
Xr2iTurbo's Avatar
Xr2iTurbo
im not sure on the compression th plate ive got in there was to compensate for the haed having being skimmed a couple of times in its life and to just lower it a little more than std,its not mega low comp or owt im at work on phone at moment i wil find out tonight though,what should it be as std any idea?thanks for all the replys
Old Mar 23, 2010 | 05:01 PM
Xr2iTurbo's Avatar
Xr2iTurbo
Old Mar 23, 2010 | 05:06 PM
jonny s2's Avatar
jonny s2
standard compression should be about 8-3-1 or there abouts im sure someone will correct me if im wrong lol
how thick was the decomp plate you ordered
Old Mar 23, 2010 | 05:18 PM
Xr2iTurbo's Avatar
Xr2iTurbo
i think it was 2-3mm im not sure as it was about 5 years ago when i fitted it,i do remember that the head has had a fair bit off it in its life though,il try find info on it in the paper work when i get time,im wondering weather to do a copression test on all cylinders now?got me thinking :-( hope nothing is gonna be wrong
jammerrs's Avatar
jammerrs
proper bottem end - ie steel pistons and rods
t3 turbo (although with your worry about lag this may not be a wise choise unless you have it built with roller bearings)
and better managment - maybe cosworth L6 or L8 or aftermarket if you can afford it
but this wont make the engine come on boost much earlier - maybe a lighter flywheel as this would help an engine rev faster so you could get on boost quicker, other than that you could get some heat protection on the turbo/manifold to help it come on boost quicker as well
how much have you got to spend?
Jonny S2 - i was reading something on turbos the other day in redline magazine and they said compression doesnt make much of a difference to lag and you could do lots of things before lifting the compression to get the turbo to come on boost faster
Old Mar 23, 2010 | 05:26 PM
jammerrs's Avatar
jammerrs
i wouldnt go t3 turbo if hes worried about lag, unless of course its got a roller bearing core
there are things you could do to reduce lag - get your manifold and turbo heat wrapped, maybe a lighter flywheel could help to im not sure...
i would look at uprating your managment - cosworth L6 or L8 or even P8 or full after market system - with a live mapping session to really get the best from it
steel rods and pistons
it all depends whats in the skyrocket, how much are you looking at spending?
make sure your car can handle the power though, good tyres, brakes suspension gearbox and clutch will be needed
if your getting a new gearbox you may as well get a diff too which sadly is more expense
EDIT: i wrote the first reply then the interent died and i didnt think it had posted so i wrote this one out, bloody computers
Old Mar 23, 2010 | 05:40 PM
Xr2iTurbo's Avatar
Xr2iTurbo
i know the bottom end needs improveing but while its still good il use it til it breaks,turbo is also quite newly re built so dont wanna change til its broken,maybe turn it up a touch though,in ur opinion would u say lagging a std manifold would be ok or wil it crack it?has any one used or got turbo wrap?seen sum on the bay,wil it cause me any problems?
Old Mar 23, 2010 | 05:47 PM
Pete frst's Avatar
Pete frst
tags are abit cruel boys...........
Old Mar 23, 2010 | 05:48 PM
Xr2iTurbo's Avatar
Xr2iTurbo
700 ish to spend,suspension is sorted although i could do with sum lower rear springs if any one has sum,its got cosworth front brakes on too so i think it should be ok to handle sum more power,defo gonna look into getting sum parts heat wrapped,any pics of wrapped manifolds and turbos would be a help too what prices roughly is better management gonna be,i think my aim is also gonna be to try reduce turbo spool up time
Old Mar 23, 2010 | 05:53 PM
Xr2iTurbo's Avatar
Xr2iTurbo
i just saw the tags they made me laugh,its a nice clean car 40k mile 1owner xr2i its not ready for scrap and burning yet!
Old Mar 23, 2010 | 06:00 PM
jammerrs's Avatar
jammerrs
no heat wrapping will be fine, you can get covers for the turbo to.
they have a double win factor in that they also stop heat getting to the airintake as mush so you get mpre power and less lag
Old Mar 23, 2010 | 06:20 PM
Xr2iTurbo's Avatar
Xr2iTurbo
thanks for ur help mate il hav a look on the bay when i get home tonight cos my phone nearly flat now cheers again mate
Old Mar 23, 2010 | 07:13 PM
rs-tuner's Avatar
rs-tuner
The other option is a 2.0 zvh will run about 230bhp on the rest of your spec
Old Apr 22, 2010 | 06:56 PM
stembo21's Avatar
stembo21
you need to get a bleed valve and open it right up till it blows up ha ha only jokeing paul
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
