Need help please!!!
Old Mar 22, 2010 | 12:26 PM
Mk3 fezza More Door's Avatar
Mk3 fezza More Door
Unhappy Need help please!!!
hi there i have got a 5 door 1994 mk3 festa and swaped the old engine for the rs1800 lump but it will not start i have swaped the ecu as well,my local auto electrician seams to think its the immobilizer how can i get past this hurdle??? please help
Mk3 fezza More Door
also the car does have an immobiliser as standard, and i can get the 1.8 to run off of my 1.6 ecu but it doesnt like it .
Old Mar 22, 2010 | 12:38 PM
ProjectBobcat's Avatar
ProjectBobcat
if they both have the same sort of immobiliser (p.at.s) then you might be able to swap the chip out of the rs1800 key into your your 1.6 one and it might work, you might need to also swap the transponder ring from around the ignition barrel for the one form the donor car, im not 100% sure
Old Mar 22, 2010 | 12:44 PM
Mk3 fezza More Door
thats the thing i dont have the key because i didnt know what age the ecu was and the guy i bought it off claimed it didnt have an immobiliser
Old Mar 22, 2010 | 01:19 PM
ProjectBobcat
there are two types of pats system, internal and external so maybe hes correct and it doesnt, i dont know anything about the year changes on mk3's. It might be worth asking on the forums at fiestaturbo.com if you get no luck here. Have the 4 digit code off the ecu to hand and they should be able to help.
Old Mar 22, 2010 | 01:20 PM
burnzy's Avatar
burnzy
burnzy
can you get hold of the bloke and ask if he can sort you the key and the barrel with the ring attached, or atleast get the chip out the key he has for the car as i think it'll work that way, i can't remember also if the ring just picks up the signal or not so just the chip out of the donor key might work.
Old Mar 22, 2010 | 05:28 PM
Mk3 fezza More Door
ok then ill try that, thanks people!!
