T5 Gearbox..........
Old Mar 21, 2010 | 03:30 PM
Hoogi's Avatar
Hoogi
Default T5 Gearbox..........
Hello,
Does anyone know the thread size for the "unusual" square headed bolts to top up the oil on a T5 gearbox ?
And also wondering what gearbox oil people recommend (Quaife gear kit fitted) ?
Many thanks..........
Old Mar 21, 2010 | 05:35 PM
I always use a gear oil, atf has little in the way of shear protection by comparison, butdoes give a better change esp when cold, having said that the synchro's need friction to work correctly and atf is just too slippery to ebanble this as well as gear oil.
I think the plug is 14x1.5.
Old Mar 21, 2010 | 07:25 PM
Hoogi's Avatar
Hoogi
"Again" cheers Tabetha...........I'll order a couple of new M14 plugs so I can ditch the square peg Ford set up
Do you recommend any make of Gearbox Oil ????
Thanks again..........
