problem with 2.9 granada
Old Mar 20, 2010 | 10:55 PM
geoffxr4's Avatar
geoffxr4
Default problem with 2.9 granada
my dad's 1990 2.9 automatic granada has got a problem that i'm hoping somebody on here can advise on. basically it has an erratic tickover but also when running along at low revs/waiting in traffic it surges/hesitates.
He's changed the TPS (to a second hand one so may still be this...?) and he's changed the idle control valve. he's cleaned out the air intake using carb cleaner too i think. Any other ideas what could be the problem?
thanks
Old Mar 20, 2010 | 11:36 PM
rich123's Avatar
rich123
air leak maybe
Old Mar 21, 2010 | 09:23 AM
Check the vac can on the gearbox, if the diaphragm is split, it allows air in and can also make the changes at different times, these are about £15 new and a doddle to change, but if wanted can get adjustable one, so you can alter the change points to a degree.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
