bosch 023 intank fule pump, HOW THE HEEL DO YOU FIT IT?
Old Mar 20, 2010 | 06:31 PM
knightsy's Avatar
knightsy
Default bosch 023 intank fule pump, HOW THE HEEL DO YOU FIT IT?
Ive just got the 380 bhp conversion from msd part of which is a bosch 023 in tank fuel pump, i have removed the tank and got the old one out but i cant see any way of fitting the new one unless im missing some bits, i asked at the time of ordering if i needed a fitting kit and was told no if you know your way around a spanner it will be quite obvious what to do when your looking at it, I cant figure it out so wondered if any of you guys may be able to give me some advice
tar very much
Old Mar 20, 2010 | 06:57 PM
COLEYST200's Avatar
COLEYST200
have you got the old one out of the tank yet and wot car is it going into
Old Mar 20, 2010 | 06:59 PM
James @ M Developments.'s Avatar
basicly, you need to cut the metal pipe which your std pump connects to on the housing, then use a small length of hose and two clips to connect the 023,
the important bit is to measure the tank depth, and make sure the 023 intake (bottom of pump) is around 5mm from the bottom of the tank, you can adjust this gap by trimming the above pipes.
secure the pump to the housing with a big jubilee clip around it onto the metal pipe.
Old Mar 20, 2010 | 07:53 PM
knightsy's Avatar
knightsy
thats what i thought but when you offer them up beside each other the 023 is so much longer i thought i would hit the bottom of the tank, il have to get some pipe and have a crack tomorrow
cheers for your help
Old Mar 20, 2010 | 07:54 PM
knightsy's Avatar
knightsy
yes old pump is out, its going in a bt escos
manuel boeckx
13
Oct 3, 2015 02:29 PM
SteveyDee
Aug 24, 2015 05:43 AM
kosienutter
31
Aug 22, 2015 09:55 AM
3doorcozmess
Aug 21, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
