stack rev counter
Old Mar 20, 2010 | 05:58 PM
B13 JUS's Avatar
B13 JUS
Default stack rev counter
just bought a second hand stack rev counter and the needle does'nt sit on 0.
is it broke or if i power it up will it go to 0?
Old Mar 20, 2010 | 06:02 PM
J1mbo's Avatar
J1mbo
B1mbo
should go to 0 when power it its a calibration process every time it is stopped and started iirc
Old Mar 20, 2010 | 06:04 PM
B13 JUS's Avatar
B13 JUS
nice one cheers mate.
is there away to check to see if it works as i bought it of ebay and my car won't be running for a while.
Old Mar 20, 2010 | 06:08 PM
J1mbo's Avatar
J1mbo
B1mbo
good question, i guess you could just power it up with a battery ? but wouldnt know where to start with it regarding wires !
Old Mar 20, 2010 | 06:26 PM
KSA-Cossie's Avatar
KSA-Cossie
Power up the red + and black - m8.
Old Mar 20, 2010 | 06:32 PM
B13 JUS's Avatar
B13 JUS
cheers mate
is 12v from a battery ok to use to power up?
also does any one know how to wire it up?
i have
2x reds from the same pin
2x blacks from the same pin
1x yellow
1x blue
1x green
1x orange
Old Mar 20, 2010 | 06:34 PM
B13 JUS's Avatar
B13 JUS
its a st408 model
Old Mar 20, 2010 | 07:22 PM
KSA-Cossie's Avatar
KSA-Cossie
Red 12v +
Black 12v negative
Blue Reset button
Orange tacho pick up point
Old Mar 21, 2010 | 02:23 PM
B13 JUS's Avatar
B13 JUS
just put power to it, the needle goes the wrong way (anti clock wise) first starts to click then goes clock wise and stops at 5500rpm.
how go i reset it?
Old Mar 21, 2010 | 02:38 PM
KSA-Cossie's Avatar
KSA-Cossie
Touch the blue wire to negative.
Old Mar 21, 2010 | 06:18 PM
B13 JUS's Avatar
B13 JUS
tried that mate but nothing happens. a red light flashed under the stack writing but only did once. touched the the blue wire to negative again and not even a red light
TPM961
Jan 15, 2018 10:50 AM
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Sep 29, 2015 09:06 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
