What shims to improve rear camber.
Old Mar 19, 2010 | 06:54 PM
lee2cossies's Avatar
lee2cossies
Default What shims to improve rear camber.
Just rebuilding the rear axle on my sapphire 2wd and was wondering if there is an easy solution to improve the rear camber for better acceleration and more even tyre wear? Are the ones from R&B motorsport the ones to get? cheers,leigh.
Old Mar 19, 2010 | 07:35 PM
JamesH's Avatar
JamesH
Yes R&B if you can't get an adjustable beam
Old Mar 19, 2010 | 08:07 PM
lee2cossies
Thanks,il give them a call monday see if they can help me.
Old Mar 19, 2010 | 08:30 PM
The R&B ones are good esp for the money, make a noticeable difference, they reduce TOE owing to where fitted as this is the bad part about cossie suspension, camber won't slow it or give inner tyre wear toe(out) does.
Old Mar 19, 2010 | 08:48 PM
lee2cossies
Sounds good.Think il go for them then.Just want a bit more traction for when i turn the boost up.Only on stage 3 til i get it mapped but when the t4 spools up its a bit twitchy,and tyres dont last long. Do i need to fit longer bearing carrier bolts when the shims are fitted?
Old Mar 19, 2010 | 08:56 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
I have the r&b shims and i cant break traction with 24 psi boost and T4, but i have all new polybushes, drop links and P zero tyres
Steve
Old Mar 19, 2010 | 09:19 PM
RS SHAUN's Avatar
RS SHAUN
Steve
how much are them steve?
have you only fitted shims?
cheers shaun
Old Mar 19, 2010 | 10:00 PM
pacwest's Avatar
pacwest
Puller of the Wrench
Using volkswagen/etc. shims you can get anyone to do this to your own spec:
http://www.merkurencyclopedia.com/Su...ear_align.html
Old Mar 20, 2010 | 08:54 AM
Papillon's Avatar
Papillon
ive got camber shims but cant see how they affect toe? any pics of the r&b one?
Old Mar 20, 2010 | 10:11 AM
KSA-Cossie's Avatar
KSA-Cossie
Felt no difference with mine,but the adjustable rear beam is amazing.
Old Mar 20, 2010 | 01:33 PM
Moonstone Steve.
cheers shaun
I did a rear end resto last year so had the whole lot off and replaced everthing with new ie bushes, anti roll bar links and diff mount, i even upgraded to 4x4 anti roll bar, my m8 who has had many a cossie and now drives a M5 was so impressed with its straight line grip, he said he hasn't ever been in a 2wd cossie with the spec i'm running and so much grip still, it just squats and fucks off . I'm not saying its all down to the shims but more a combo of everything being new it just feels so tight even round corners at speed, rather than a sloppy worn out back end.
Steve
Old Mar 20, 2010 | 01:36 PM
Moonstone Steve.
£10 on the randbmotorsport website
Steve
Old Mar 20, 2010 | 02:00 PM
KSA-Cossie's Avatar
KSA-Cossie
Steve
Nothing worse m8.
Old Mar 20, 2010 | 02:06 PM
JamesH's Avatar
JamesH
Old Mar 20, 2010 | 09:41 PM
Moonstone Steve.
Originally Posted by KSA-Cossie
Nothing worse m8.
You've met the wife then
Steve
Old Mar 20, 2010 | 09:54 PM
Sonic Boom's Avatar
Sonic Boom
I've tried ringing R&B motorsport all day for some shims everytime I try it's engaged and it won't let you do ring back
Rich
Old Mar 20, 2010 | 10:08 PM
KSA-Cossie's Avatar
KSA-Cossie
Steve
Lovely woman,doesn't talk highly off you though lol.
Old Mar 21, 2010 | 12:24 AM
lee2cossies
Sounds good,il order some and give them a try.Iv just done a rear end resto myself,new bushes,diff mount,bearings,drop links etc so hopeing it should be a bit nicer all round.
155lee
Sep 6, 2016 11:10 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
grishenko45
Sep 9, 2015 12:58 PM
cossirob
Sep 3, 2015 09:17 PM
