fuel pressure gauge
Old Mar 18, 2010 | 04:38 PM
davecosworth's Avatar
davecosworth
IM BACK
Default fuel pressure gauge
has anyone modified there fuel pressue rail to take a fuel pressure gauge to be left on all the time,if so some pictures would help just thinking about doing that way or buying a pressure regulator with a gauge already in it what you guys thinking
Old Mar 18, 2010 | 05:17 PM
cozzy jeff's Avatar
cozzy jeff
this is one on my wrc inlet
Old Mar 18, 2010 | 06:05 PM
davecosworth
IM BACK
thats exactly what i was thinking on doing. did you weld it or braze it to the fuel pressure rail
Old Mar 18, 2010 | 06:37 PM
cozzy jeff's Avatar
cozzy jeff
it came like that when i bought it new from pj motorsport,i have in the past had -6 fittings brazed onto the fuel rail with no problems, so would do it that way.others might have other ideas.
Old Mar 18, 2010 | 06:39 PM
I did one for sir nose, turned a bit of metal tapped it to suit then it was braized onto the fuel rail, braized as the rail is SS and the bit I made was mild steel.
To my mind it is either a gimmick, or if wanting it for warning purposes why put it under the bonnet, the one I did had a pressure sender screwed in for a dash gauge, with alarm.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dubs44
Sep 19, 2015 06:31 AM
