Sapphire boot locking problem
Old Mar 17, 2010 | 11:03 PM
RSLUBBY's Avatar
RSLUBBY
Default Sapphire boot locking problem
Hi Can you help my saffs(2wd) boot wont lock when you hit the central locking or if you try and lock manual. The solenoid is moving the lock latch over but still wont lock. Do saff book locks have a prblem locking cause this aint the first.
Help please
Ian
Old Mar 17, 2010 | 11:05 PM
RSLUBBY's Avatar
RSLUBBY
Default x
y
Old Mar 18, 2010 | 02:17 PM
Are you certain the plunger is 100% fully out, mine is always getting stuck in, but this is due to roofing tile grit covering the boot and lock, and jamming it, I have to sometimes use a block of wood to thump the button in to get boot undone.
They are very easy to take out, only 5 minute job, not even that fiddly, but watch out if it's windy, as sapphy boot smacking you on the head hurt!!
I'm changing to a 4wd flush boot lock owing to where I need to park my car.
Old Mar 18, 2010 | 02:44 PM
rog's Avatar
rog
Never had this issue as i don't have the lock/key anymore, just the lock mechanism and solenoid inside. But as Tabetha has said, it's very easy to dismantle, take it out and give everything a good once over and clean and see where the problem is at, from what your saying it sounds like the actual lock is buggered though.
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
