t4 with standard comp safe?????
Old Mar 17, 2010 | 10:18 PM
forevaford's Avatar
forevaford
Default t4 with standard comp safe?????
as title, i have an half decent engine spec with around 350 ish bhp, i got woosner pistons but std comp. will i have det problems with say 33psi boost? use water injection??
just lookin for oppinions really
Old Mar 17, 2010 | 10:22 PM
Mark Shead's Avatar
Mark Shead
As long as you have it mapped you will have no problems,
You will get surge on a T4 at that boost without cams.
Mark
Old Mar 17, 2010 | 10:28 PM
forevaford's Avatar
forevaford
thanks mark, interms of cams, it has a bd14 inlet, and std exhaust. it has ported head too
Old Mar 17, 2010 | 10:30 PM
Mark Shead's Avatar
Mark Shead
Then you should be ok but I have not run a BD14 on that spec.
Mark
Cosnada
Jan 7, 2016 05:30 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
