boost
Old Mar 17, 2010 | 05:51 PM
lukeyboy's Avatar
lukeyboy
Default boost
whats wrong when your car doesnt hold boost
Old Mar 17, 2010 | 07:19 PM
oldford's Avatar
oldford
Seized turbo, split intercooler, engine worn, take your pick.
How about some more details? Like what car, how much boost do you get, etc.
Old Mar 17, 2010 | 07:22 PM
lukeyboy's Avatar
lukeyboy
its an escort cosworth it hits 30psi and holds 25psi
Old Mar 17, 2010 | 07:49 PM
oldford's Avatar
oldford
So, it does hold boost, just at a lower level than you think it should be?
And how much boost do you expect it to hold?
Did you check anything and if yes, what?
Old Mar 18, 2010 | 08:13 AM
Kelv's Avatar
Kelv
Almost there!
that sounds about right, especially if its a slightly old actuator going weak.
Old Mar 18, 2010 | 10:46 AM
grcossie's Avatar
grcossie
Weak actuator is my gess to
Old Mar 18, 2010 | 10:47 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
What turbo?
What chipset?
What actuator?
Did it used to hold more boost?
Old Mar 18, 2010 | 04:12 PM
lukeyboy's Avatar
lukeyboy
its got a t34 turbo ahmed bayjoo chip and a collins 31 actuator it used to hit 35psi and hold 30psi at 430bhp
Old Mar 18, 2010 | 04:16 PM
Chip's Avatar
Chip
Possibly just a weak actuator then mate but thats MONSTER power for a T34 though (more than I would of thought possibly TBH!), so it could well be showing some signs of not wanting to do it anymore.
Old Mar 18, 2010 | 05:55 PM
lukeyboy's Avatar
lukeyboy
its running rs 500 setup with eight injecters light blues it had just under 400 lb of tourque
Old Mar 19, 2010 | 02:46 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Running that kind of boost needs an inconnel arm on the wastegate. What has happened is that the turbo has got hot and the arm has twisted so now it is bleeding off a bit of boost. You can adjust the actuator, but you will find that now that has twisted it has weakened it, so it will keep doing so until you run out of adjustment on the actuator.
An inconnel arm is made out of the same material they use in jet engines, so is more than able to take the temps the turbo generates without twisting.
However, I personally think that is WAY too much boost for a T34, and it SHOULD be tailing to 26psi by 7000rpm anyway, or it WILL die (the turbine will shit a blade) .
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
