NEWBIE Sapphy.....
Old Mar 17, 2010 | 04:05 PM
gibbo1979's Avatar
gibbo1979
Default NEWBIE Sapphy.....
Hi everyone. Ok so at the age of 30 i have my first cossie. An 88plate 2wd sapphy. Its doing 408bhp and seems reliable. I have a few questions and hope peeps can help me out....
1. I dont seem to have any instrument lighting anywhere on my dash board! All the warning lights etc work just not the back lights when i turn on side or full headlights?
2. I have the bottom half of the amal valve and not the top, do i need a new one or will it run right with this?
3. The idle sometimes goes weird and then better again, flutuates between 1000rpm - 2000rpm at cold then its ok once warm? Anyone any ideas?
Apart from this its a really smart fun car and i can see why people get hooked.
Old Mar 17, 2010 | 04:11 PM
fezzajsy's Avatar
fezzajsy
looks very nice and clean mate,ps welcome to PF.
do you have pics of the amal valve?
ZetecSX's Avatar
ZetecSX
ITB's... Loud and Proud
looks stunning mate... great example with some serious HP.. very jealous... sorry i cant help with the querries...
Old Mar 17, 2010 | 04:35 PM
cossiejsy's Avatar
cossiejsy
Hello and welcome to pf
Nice motor
Old Mar 17, 2010 | 04:42 PM
LHD220Turbo's Avatar
LHD220Turbo
the lights on the dash are a normal thing; some of mine didnt work; it will probably be wiring if its all the light
the cold start issue with regards to the idle will be the ISCV which will either need replacing or cleaning; its located on top of the throttle body
Not quite sure what you mean with regards to the amal valve
please please please, go and get the car checked out for a fueling check by someone who knows what they are doing, as you are in cheshire i would take it to Tony at Turbo Systems
Old Mar 17, 2010 | 04:48 PM
KSA-Cossie's Avatar
KSA-Cossie
Looks nice m8.
Old Mar 17, 2010 | 04:54 PM
opposite lock's Avatar
opposite lock
Welcome aboard im too very jealous at the power level(double standard power) thats some great advice from LHD220TURBO , good luck with the new partnership pal,enjoy
Mike
Old Mar 17, 2010 | 07:09 PM
gibbo1979's Avatar
gibbo1979
Thanks Everyone i just spent an hour trying to get vid and pics up on here but it crashed haha so will do it tomorrow.
Old Mar 17, 2010 | 07:40 PM
As said looks nice and clean, good advice for a fuelling check, just take it easy till then, and see that the fuel pump rewire and fan rewire have been done, then do a mega service inc the fuel filter, very often forgotten as out of sight.
Old Mar 18, 2010 | 09:46 AM
gibbo1979's Avatar
gibbo1979
Hi everyone..... ok here are the videos and images of the car and what she isnt doing hehe...... Any feedback greatly appreciated
NO DASH BOARD LIGHTS EVEN WHEN SIDE LIGHTS ARE ON. I have checked the dimmer switch by the way lol. Is there a plug that could be off somewhere or a fuse blown? Its just weird how no lights are on but it signals and warns me , handbrake light etc etc ????
WHATS THIS?....Does anyone know what this plug is for, it was just lying behind the radio cassette player?
AMAL VALVE... OR WHATS LEFT OF IT. Do i need to get another or is this ok as it is.
Thanks Everyone and hope to meet you at some meets this year
Old Mar 18, 2010 | 01:37 PM
martysmartie's Avatar
martysmartie
Hello and welcome nice looking saff, likewise about meets
The Amal valve (Solenoid) is missing you actually only have the casing. You would need another soon as you can't buy the two bits separately. That is actually very dangerous as you have no boost control at the moment.
There should be a black electrical plug which connects to amal valve which I can not see in picture so see lying round near the slam panel.
Idle issue I have the same issue with my car I just disconnected ISCV is a common issue, but ideally you would want to replace sometimes a clean with WD40 or the likes can sort.
Good advise for fuel pump wiring + filter also make sure your cooling fans work, they may have already been re wired which is more than likely.
As for lights check to see if number plate lights or back side lights can't remember which way round now work, if not will more than likely be the fuse as this protects these along with the panel light circuit.
As for wire behind cassette can't answer but make sure none of the wires behind here are trapped/exposed as this could be shorting causing light problem.
Martin
Old Mar 19, 2010 | 04:23 PM
gibbo1979's Avatar
gibbo1979
Thanks everyone..... I have just got some AVO springs to send her back up to standard cossie ride height. But they are uprated. I think it will look much better with this set up (running bilsteins for the shocks).
I got The AMAL valve and was wondering can i just put it back on and then off we go again? Im thinking of of taking her somewhere and getting a new wastegate put on and then set up properley. thinking MSD or Well Lane Turbo Centre.
As for the lighting issue on dash board..... the problem still remians but i will sort it out. By the way she is now called "Izzy the cossi" haha.
Hope ya'll havin a good day in this spring weather.
Old Mar 19, 2010 | 04:46 PM
LHD220Turbo
why do you want a new wastegate? or are you talking about the wastegate actuator?
you've got turbosystems on your doorstep virtually; take it there!
Old Mar 19, 2010 | 07:23 PM
Hello nice car mate.
Old Mar 19, 2010 | 10:00 PM
nuttynil's Avatar
nuttynil
RS nutta
wellcome love the colour#
Old Mar 20, 2010 | 08:14 PM
Saaamon's Avatar
Saaamon
Def get the whole car checked out before driving it hard again, could get expensive otherwise.
Old Mar 20, 2010 | 08:18 PM
KSA-Cossie's Avatar
KSA-Cossie
Get yourself to turbosystems for a check up m8.
Old Mar 20, 2010 | 11:07 PM
AndyPen's Avatar
AndyPen
Check it and play carefully for a while - that's a lotta power you'll have there once it is sorted - welcome to the 2wd nutters pal
Old Mar 21, 2010 | 09:00 AM
Turbosimpsons's Avatar
Turbosimpsons
get yourself over to Turbosystems tony's the best person to give you honest advice. just don't ask for any advice on marriage
Old Mar 22, 2010 | 10:06 PM
gibbo1979's Avatar
gibbo1979
Hi All........... ok i got the amal valve now and was told that it best to get a wastegate actuator sorted as they tend to slacken over a while and you can only wind them out so much. So yomorrow Amal Valve and new Avo uprated springs will be fitted, then i shall call Tony @ Turbosystems and Stuart @ MSD for their advice and prices on getting the car setup perfectly. Thanky ou for all the advice and i wont be driving it hard until i have it all set up. GREAT ADVICE form everyone, what a wonderful forum this is. I love the RS scene
Old Mar 22, 2010 | 10:14 PM
Delta-Force's Avatar
Delta-Force
looks a nice clean motor pal hope you get along well with it
Old Mar 22, 2010 | 10:31 PM
Turbosimpsons
where bouts in cheshire are you?
Old Mar 22, 2010 | 10:35 PM
LHD220Turbo
the spring in the actuator does go weak over a extended period of time; but please dont go adjusting the actuator rod until you get it set up
if you shorten the rod you will increase boost.....too much boost + not enough fuel in the map = bang bang engine. listen to the advise here and dont drive the car until its been fuel checked, it will all end in tears otherwise
Old Mar 23, 2010 | 09:17 AM
gibbo1979's Avatar
gibbo1979
A RS LICKER..... im over near knutsford mate where are you ?
LHD220TURBO..... My mits are not touching a thing hehe. So "Izzy" shoul dbe safe in that respect .... always letting the experts/professionals under the bonnet, i shall deal with the cleaning mate lol
Old Mar 23, 2010 | 09:33 AM
Turbosimpsons
Thumbs up
Congleton. get it over to Turbosystems, it couldn't be in better hands. iv'e got a escos at Turbosystems being built. pop in for a brew.
Old Mar 23, 2010 | 10:08 PM
Saaamon's Avatar
Saaamon
Your car will love you for that.
Old Mar 24, 2010 | 07:49 PM
gibbo1979's Avatar
gibbo1979
Hi All. The cosworth is now looking sweet with her new avo springs and loving her stance (pics to follow). Also go tthe new Amal valve sorted and have booked her in to Turbosystems with Tony. MSD were alittle vague as to what would need doing and i got the feeling the price would just go up and up! Anyhoo.... Tony made me feel like i am choosing the place for her. Also got the dash board lights sorted so thanks to Marty Smarty for the advice regarding the number plate lights..... yes they are on the same circuit. Woohoo.
Old Mar 25, 2010 | 02:10 PM
martysmartie
No problem, glad it's sorted and I could help.
Martin
Old Mar 26, 2010 | 09:26 AM
gibbo1979's Avatar
gibbo1979
Now thinking of booking Izzy into Well Lane. Anyone any thoughts on this? They can rolling road print out aswell thats why i wanna take it there. woohoo
Old Mar 26, 2010 | 05:59 PM
LHD220Turbo
well lane as opposed to turbo systems? i dont think well lane have got the best reputation. As with tony at turbo systems is one of the top guys
Old Apr 5, 2010 | 06:51 PM
gibbo1979's Avatar
gibbo1979
Thanks for the opinion LHD220Turbo.... as with all your advice i shall tak eit in and end up acting on it giggles. Maybe just a rolling road run then at Well Lane
Rammer46
Sep 18, 2015 08:31 AM
Bezzy41
Aug 3, 2015 10:31 AM
markymark7890
Aug 23, 2005 09:30 PM
craig b
Fiesta RS1800/RS Turbo
Aug 6, 2005 03:51 PM
Ford Focus RS
Dec 31, 2003 07:02 AM
