welding a temp sonsor on sump, does it matter where its put?
Old Jan 10, 2005 | 01:49 PM
Gra's Avatar
Gra
Default welding a temp sonsor on sump, does it matter where its put?
Due to the spectacular lack of intructions with my gauges i need to ask a quickie, i am gonna weld the sensor in the sump for the oil temp, but wanna check does it matter where its put or should it be put in an certain area?
Old Jan 10, 2005 | 02:25 PM
CabrioTurbo's Avatar
CabrioTurbo
fooking hell man! you dont need to weld the sender into the sump!
You need to get a adapter so you can fit the sender where the sump plug goes!
Old Jan 10, 2005 | 02:41 PM
Gra's Avatar
Gra
opps, i asked on here, and was told, opps
https://passionford.com/forum/viewto...602&highlight=
Old Jan 10, 2005 | 02:44 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
you can actually get sump plugs that are oil temp sensors aswell.
fook knows where from tho...
Old Jan 10, 2005 | 02:47 PM
CabrioTurbo
well you can weld the fookerinto the sump if you want to! its just a bit easier to get a sump plug adapter if you ring nomad and ask if they will sell im to you youll be ok... otherwise i dont know where you will get an adaper from... and you prob will end up welding a nut onto the sump...
to do that you will need to take the sump off etc so it wil be a bit of a bastid!
slammedorion
15
Nov 1, 2015 07:17 PM
Derek Burleigh
Sep 16, 2015 06:27 PM
Harryh24
Aug 26, 2015 07:50 PM
Gadget
Aug 26, 2015 01:02 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
