Timing belt and water pump xr3i
Just bought an K reg xr3i 1.8 16v, It broke on the way to me, when you go to turn the engine over it seems to of lost compression and wont start, There was water every where on the floor of the tow truck and the timing belt has jump a tooth or so as its not broke but ever so slightly slack so my instant thought is the water pump has gone but not sure if im right please if any one has any ideas please let me know thanx
Also when you turn it over it thers no knocks or funny noises just sounds like loss of compression
Last edited by leeboy_09; Mar 16, 2010 at 08:31 AM. Reason: forgot to add somthing
Does sound as though could be the water pump, or a split pipe, hopefully you might be lucky and get away with no valve damage, certainly worth putting a new belt and tensioner on first to find out if compression is ok.
I hope so, got all the parts now so me and my mate are gunna crack on with it in the morning so fingers crossed
Ill post up on here tomorrow and let everyone know the verdict lol cheers for replying
