Shit brakes on my 2wd cosworth
Old Mar 15, 2010 | 07:36 PM
Rollin Rides's Avatar
Rollin Rides
Anyting forsale let me no
Default Shit brakes on my 2wd cosworth
Right i have rebuilt all the brakes on my saph, they all work proppely just dont seem too have the power to slow you down quick enough.
The discs are black diamond grooved ones and im running EBC red stuff pads.
I would like better braking just dont wont to change my wheels which are escort cosworth 8x16.
Please anyone with ideas help my out i have seen some on Ebay just abit exspensive.
http://cgi.ebay.co.uk/FORD-SIERRA-CO...item483955ce55
Old Mar 15, 2010 | 08:33 PM
How many miles have the discs pads done ?
Did the pads have the break in coating on them a really rough surface like a ripply surface ?
They should feel extremly good do they need bleeding or is the pedal hard, with no free play, when you rebuilt your brakes do you mean new seals etc, as the pistons regularly seize on 2wd, my car had 6 out of 8 seized when I got it.
Old Mar 15, 2010 | 09:16 PM
bad boy rs's Avatar
bad boy rs
get some ds2500 pads off matt lewis mate
Old Mar 15, 2010 | 11:13 PM
Rollin Rides
pads where band new as were the discs. new rear calipers and complete over haul on fronts ie; pistons, seal, dust covers...
what are my opitions?
Old Mar 15, 2010 | 11:18 PM
m4tt274's Avatar
m4tt274
myn will jam the wheels solid. they stop you brillianty.. once, maybe twice lol they fade like mad
Old Mar 16, 2010 | 05:10 PM
The redstuff has better co effecient friction wise at lower temps, so work better sooner, there's something seriously wrong, are they binding at all ?, if they were they could be overheating, the ebc pads with brake in coating can be a bit hairy, I usually take the brake anti rattle shim off the rear of the pad as well, did you need to apply any force to get them in ?, some aftermarket pistons can be a tad longer and so the new pads, new discs can cause a bit of binding, but you'd notice this as soon as pulling away.
Old Mar 17, 2010 | 09:50 PM
Rollin Rides
brakes work like they should ie; no binding they just dont slow me down quick enough. every thing is good just when ur havin it and really need them like coming up to a roundabout and stamp them on they just dont grab you that much. i do like to brake late!
Old Mar 17, 2010 | 10:22 PM
JoeRS22's Avatar
JoeRS22
A= brake earlier...
B= sell the car...
C= get your tight wallet out and buy some bigger brakes!!!!!!!
Old Mar 17, 2010 | 10:47 PM
Rollin Rides
joe i still want my wheels... why is it so hard to find some!!!!!!
Old Mar 18, 2010 | 02:22 PM
You sound just like me, I must admit if doing say 80 plus(on a private road) they don't stop as quick as I'd like, think it's more down to the relatively small diametre disc considering the weight of the car, and the likely speeds, if I have to stamp on from speed my bum cheeks clench a bit!!
Time for a brake upgrade, I have me FRS brackets ready for me 2wd 4 pots, just got to get the discs, when I get me new wheels, but having trouble finding exactly what I want.
Old Mar 18, 2010 | 04:31 PM
Rollin Rides
does any one no if you can fit the brembos under 16" wheels?
Has anyone dont it and can help me. cheeRS
Old Mar 18, 2010 | 05:59 PM
m4tt274's Avatar
m4tt274
seal kit in the master cylinder. how many miles has the master cylinder done?
Old Mar 19, 2010 | 12:07 AM
Rollin Rides
80,000? i dont get any fade....
Old Mar 19, 2010 | 07:57 AM
kcosneil's Avatar
kcosneil
i've got ebc drilled and grooved disc and yellow stuff pads on my escort cossie.
not to good around town but when your bomming about and they get hot there pretty good.
original
Jan 30, 2022 08:20 PM
jason_nike
Aug 18, 2019 10:53 AM
bigluke200
14
Sep 2, 2015 10:35 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
