Any gas fitters on here?? Copper pipe question
Hi all,
I want to cap off a 15mm gas pipe on an outside wall which runs to where an old cooker used to be, i went to wickes to get a cap joint but on the back of the solder fittings it says not suitable for gas!! I can understand it for push fit or compression joints but not soldered joints as the 22mm pipe which runs along the side of the house has soldered joints and fittings along it ( not the pre soldered type )
Which fittings can i use? I just want to cap off the 15mm pipe as i can't get to the 22mm T easily to change it to a straight!
Cheers, Gaz.
Cheers, Gaz.
some gas pipes aren't the same size as water pipes. which is why they may not work or be interchangeable
that and the fitting might not be properly sealable against the gas
i know we had a world of trouble tring to sort our gas pipes out when we moved in, in the end we got the gas man to start from scratch as my brother decided to put screws through the pipework on 2 separate occasions
twat was without gas until they could come out and sort the problem, they put a prohibition notice on
copper pipe is copper pipe , the only differences if any will be imperial or metric old size is 1/2 inch new size is 15mm you can buy couplers that change or use a compression fitting with an imperial olive...................or you can pay me to come and do it
I'll get the verniers out then and check the pipes 15mm, not half inch. Thanks fellas, soldered cap it is then.
