Running in periods!
Old Mar 15, 2010 | 04:50 PM
RS-ads1986's Avatar
RS-ads1986
Default Running in periods!
Hi does anyone no what the running in period is on a mk2 focus rs ?
Old Mar 15, 2010 | 05:18 PM
S1's Avatar
S1
Thought this was gonna be a question about the missus jogging during the curse.
Old Mar 15, 2010 | 05:55 PM
There's seriously little needed these days due to vastly better components closer tolerances than years ago, a few hundred easy miles with no loading then drive as normal, I'm at full revs by 500 miles for short periods, the cross hatch honing that is done on bore walls greatly helps the rings bed in, as it traps oil until worn a bit, this helps the rings to prevent dry running.
Old Mar 15, 2010 | 06:12 PM
rs-tuner's Avatar
rs-tuner
as said do 1000-1500 miles then change the oil and filter thats what i would do anyway
Old Mar 15, 2010 | 06:15 PM
Rsmat's Avatar
Rsmat
500 mile its states but id do 1000 to be sure mines only done 209 tho.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
