1.8 TD escort estate Immobiliser. WRECKIN MY HEAD!
Old Mar 15, 2010 | 09:45 AM
Roberto_98's Avatar
Roberto_98
How ye lads
Default 1.8 TD escort estate Immobiliser. WRECKIN MY HEAD!
Can anyone help please??. The immobiliser beacon light is flashing erratically on my car. It won't turn over and there is no heater light coming on in the dash . It was lying up for a while but was running fine one day and the very next day it didn't. It's not a battery problem or anything as i've looked into that. Is there any way of removing the immobiliser or bypassing it? Thanks everybody.
Old Mar 16, 2010 | 08:48 PM
cabriolet's Avatar
cabriolet
look at the pump loom that runs over the radiator it chafes through and causes similar symptoms to this
Old Mar 16, 2010 | 09:24 PM
xr2john's Avatar
xr2john
Passionford Addict
if its a mk5 model that has the red flashing light beside the clock you can simply pull the fuse for the immobiliser,crackin job ford...lol
if you look on the fuse box panel the immobiliser circut is the 1 that has the symbol of a padlock if i remember correctly,as far as i know all your mk5 from 1992-1996 are all the same
hope this helps
Old Mar 17, 2010 | 08:55 PM
Roberto_98's Avatar
Roberto_98
How ye lads
hope this helps
thanks i'll take a look at loom. i didn't know that. i should probably mention it's a 98 model.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
