2004 ST 170 Engine warning light
Old Mar 14, 2010 | 08:14 PM
mattrobbs's Avatar
mattrobbs
Default 2004 ST 170 Engine warning light
Basic problem but hoping you can help - engine warning light came on after starting car from cold and driving a few metres. Not flashing but not going off even after topping up engine coolant (which had been low). No other warning lights on. Any ideas? Cheers.
Old Mar 15, 2010 | 01:36 PM
melinamotor's Avatar
melinamotor
Farpylee
Lambda sensor on the Cat maybe?
Old Mar 15, 2010 | 04:33 PM
TomStarkey's Avatar
TomStarkey
if it came on because of your low coolant it wont go off till it gets reset... I think
Old Mar 15, 2010 | 07:21 PM
RichieST's Avatar
RichieST
It won't come on because of low coolant. Disconnect the negative lead off the battery for about half an hour to reset light and see if it comes back.
Lambda sensors always go on the st170's. If it is this it won't damage the engine to drive it with the light on, but best to get it sorted soon-ish!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
