gt45 onto t25 manifold?
my car is running twin t25 turbo's and im changing it to a single turbo i have a gt45 turbo to go on
but my manifolds are to fit t25 etc what would you do is there a flange to fit the gt45 or would you just make a new manifold to suit?
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
GT45???? You are aware that is a 1000bhp turbo????
As you can't get an internally gated GT45 you'll need to run an external wastegate for boost control, the external wastegate take off will need to be integrated into the exhaust manifold. Plus if you are going for a GT45 i strongly suspect you'll need alter its position for clearance... I'd suggest getting a manifold made!
yea thats what i thought im going to run it on the passanger side and remove my battery and battery tray i have the scimatics of what i need to do with the manifolds and downpipes just alot of bending and welding
i know its a 1000 bhp turbo but i already have it so might aswell what kind of bh u reckon that would put out at 20psi? for example
na like i say i already have the turbo so ill run low boost and see how we go i mean the skogenracing lads run stock engines with bigger injectors m/s ecu with these turbo's and getting around the 400bh mark
Personally if it was my car i'd be putting something more T4/GT30 sized on as a single turbo and stock engine, should be nice and responsive as well as making the same power!
yea thats no problem as ill make a manifold flange that can be exchanged for others so not too much of a problem,pretty simple set up realy should have it done in the next month or so would be quicker but due to work
its finding the time
caprixpack
Sep 25, 2015 07:53 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Si B
Sep 12, 2015 06:49 AM
