wierd sierra cosworth problem help! take 2 HELP
Old Mar 14, 2010 | 07:56 AM
RS Classics's Avatar
RS Classics
Default wierd sierra cosworth problem help! take 2 HELP
if you read my other post my sapphire is a wierd starter. some times it goes first time you turn it over then it can take ages for it to start. so i tried a p8 in it and it starts fine first go every time but boosts wierd so i put another l8 in that we had and it does the same thing as the other l8. runs fine when it runs but takes an age to start sometimes. is it just the l8 ecus that do this or is it a fuel pump prob or something??? help please
Old Mar 14, 2010 | 08:53 AM
Stu @ M Developments's Avatar
PassionFords Creator
Its almost always a Crank or Phase sensor problem. Usually phase.
Old Mar 14, 2010 | 08:54 AM
RS Classics
have changed them all before. the wierd thing is is that the p8 worked first turn every go? its a lambda sierra
Old Mar 14, 2010 | 09:04 AM
RS Classics
have changed them all before. the wierd thing is is that the p8 worked first turn every go? its a lambda Sierra
Old Mar 14, 2010 | 09:24 AM
Check the alignment and gaps. Its the fact that your P8 works that is directing me to those sensors, but I dont currenty have time available to explain why that is.
Old Mar 15, 2010 | 06:47 AM
RS Classics
does the p8 work differently with the gaps
Old Mar 15, 2010 | 08:24 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
the p8 has a very clever function called error mask
Old Mar 15, 2010 | 08:33 AM
RS Classics
huh really could you explain this because it would be very interesting to know about
Old Mar 15, 2010 | 10:16 AM
Toe Knee's Avatar
Toe Knee
at an uneducated guess the P8 isnt as fussy about the gaps being 100% right as the L8 is and compensates for it.....
Old Mar 15, 2010 | 10:37 AM
ECU Monitor Enthusiast
Allow me Stu...
The P8 has better signal processing amplifiers on the sensor inputs and is more tollerant to noisy and/or low voltage inputs.
Low voltage output from the crank/phase sensors can happen as they age or the gaps are wrong.
I.E. The older ecu's require a clearer stronger signal over the P8.
Tony is probably busy so allow me...
This is a function where the ecu software tracks the normal sensor inputs.
If one or the other fails, the ecu can continue to run normally as it knows where it was (or should be) so assumes it can carry on the same sequence of events.
However, this normally triggers a limp home mode so the car can still be driven but at a reduced RPM or boost level to prevent possible engine damage from incorrect ignition timing positions.
Old Mar 15, 2010 | 07:48 PM
RS Classics
So that would explain the weird boosting and idoiling in the p8
Old Mar 15, 2010 | 09:43 PM
Its more likely the chip you have for the P8 is less suited for your engine that the other.
Old Mar 16, 2010 | 12:09 PM
Turbosystems
Super Moderator
Originally Posted by Flux Capacitor.
Allow me Stu...
If The P8 goes into Limp home it will limit rpm to 4000 rpm
Old Mar 17, 2010 | 06:40 AM
RS Classics
the sensors are all new all spaced correctley and still the same. runs fine just doesnt start good. and is extremely annoying
Old Mar 17, 2010 | 08:40 AM
Ignoring the ecu types for one moment, the chips for both will be different even though they may be for the same engine setup and state of tune.
It does sound like to me the chip in the L8 may need extra fuel for starting in the map !!
Old Mar 17, 2010 | 08:43 AM
RS Classics
i had a standard l8 in it that its always had never EVER opened and at the moment i have a different chipped one in it for more power but both the l8s start the same.
Old Mar 17, 2010 | 08:54 AM
So are you saying one of the L8's is totally original, and the other has an uprated chip ?
What state of tune is your engine ? (map sensor type/ injectors/cams/turbo etc... )
Old Mar 17, 2010 | 09:35 AM
RS Classics
Yep and both do the same. As for the engine all standard for a 4x4. Brand new engine done about 700 km
Old Mar 17, 2010 | 09:54 AM
A quick experiment to try...
Disconnect the vacuum hose from the fuel pressure regulator....
Does the car start up quicker and idle better ?
(This should enrich the fuel slightly during starting)
Do not drive the car like this !
Old Apr 12, 2010 | 05:32 AM
RS Classics
turns out it was the knock sensor. the wire must have been shorting out on the body somewhere because the wire was split
Old Apr 12, 2010 | 10:43 AM
PAUL S's Avatar
PAUL S
goes to show all the above fellas know there stuff, they all quickly said crank sensor issue of some kind or another
handy info to know
Old Apr 12, 2010 | 03:28 PM
glad its sorted fella.
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
