Car battery help please ***updated****
tryed to start my cosie today and battery was flat so charged my battery and still nowt so take it i need a new battery,
where from and how much please people??
Not many manufacturers make batteries with square terminals no more
I have just replaced the battery in my car with a Yuasa item, I've seen them on the bay for a bullseye
Luciano
Luciano
sorry to sound thick but im new to this my first cossie how do i check my starters nakered? and would a boost pack make a difference do you think as im going to try that 2mro
Imo cosworths always sound lazy turning over compared to normal cars and then they go brrrrrrrrrrrrrrrrrrr
makes it all worth while.
As said stick a booster on and see how you go from there.I did replace the battery on mine and didnt have a problem getting one but that was about 2yrs ago and from what I have read people have probs getting them now and have even changed the terminals to round ones.
well il get a lend of my mates booster tomorow and see what happens,is there much involved in changing to difrent terminals basically how muchg lol as all my money is going on trying to get the beast on the road ha
you can get converter terminals from flat to round post
some here http://cgi.ebay.co.uk/Flat-Post-Conv...item5ad7e5fba2
well basically ive put the booster pack on it and all im getting when u turn the key is a really load sort of ticking sound but not turning over or starting do you think my battery is just completed f***kd or ???? im gutted bought the car neededing bits and pieces just want it on the road 1 thing after another lol
on the other note do the lights go dim when trying to start the car if so could be the battary but it sounds more like the starter motor is fucked
Dont assume it's the starter based on this, if your battery is sick enough it will absorb all the power from the jump pack as well, leaving nothing for the starter.
If you just buy some round post terminals that have the 2 screws that hold the main cable in, all you need to do is put a long bolt through the terminal where the cable would normally go, then nut other end screw the ford flag terminal on this way, don't need to cut anything.
This is getting away from the fact that they are easy to get, ford terminal batteries that is, www.carbatteryshop.co.uk, I always recommend and use Varta Blue, I was lucky and picked up a varta blue for Ł50 cash as it was old stock, still 5 year warranty though, a 097, biggest that will go in the tray.
would this be any good anybody know id prefer to get one that will fit straight in without any cutting or joing ect if anybody knows of anywhere cheers
http://www.advancedbatterysupplies.c...tablued59.html
you need to check voltage at the battery with a multimeter and see what it is when trying to crank. could be some thing as simple aas the starter solinoid trigger wire is fucked?? don't shell out for a new battery until your sure it's at fault. take the battery completely off the car and put the jump pack in inits place then try to start it.
cheers,
Phil
cheers,
Phil
Ive just gone to start up my ERST having been laid up for many years. Though the engine was sezied as it refused to turn over. Looked under the bonnet under cranking and found the alternator was seized. Once I removed the fanbelt it spun up lovely. Still didnt start though, frikkin mfi lol!
track.focus'd
Aug 12, 2015 05:53 PM
liam-rst
Aug 10, 2015 08:46 AM
