3 bar map sensor
Old Mar 13, 2010 | 06:15 PM
steveo135's Avatar
steveo135
Default 3 bar map sensor
Hi Guys
Is thier anyway of testing if one has gone tits up.
thanks steve
Old Mar 13, 2010 | 07:48 PM
oldford's Avatar
oldford
Measure voltage. Ecu supplies a 5 volt feed and earth.
With key on, engine off the signal should be around 1.5 volt.
With the engine idling and warm it should be below 0,5 volt.
Old Mar 13, 2010 | 08:15 PM
As above or use a vacuum pump/pressure pump to test the whole range.
Old Mar 13, 2010 | 09:37 PM
steveo135's Avatar
steveo135
Default Cosworth
Thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
