6 Degree rear beam-fitted and set up!
Old Mar 13, 2010 | 05:46 PM
105epwr's Avatar
105epwr
Default 6 Degree rear beam-fitted and set up!
Hi,thought i would share this with you guys,i fitted a scs rear beam through winter and had it set up there last sat and had it out today for the first time i cannot beleive its the same car!!!
on slight corners on roads wheres before im on/off power
now it can be held flat out through slight corners and feels very stable at higher speeds,and when the back breaks away it dont violently snap back the other way it just comes back in nicely now.
anyone considering this conversion its well worth it
Old Mar 13, 2010 | 05:51 PM
grcossie's Avatar
grcossie
I really want one of this
Old Mar 13, 2010 | 08:19 PM
Ridgey's Avatar
Ridgey
Just fitted one, got to sort my exhaust hangers then a setup. Looking forward to it.
Old Mar 13, 2010 | 08:22 PM
I would hope it would do something special for the "special" price, glad to see it does.
Got your 22mm arb on yet, or was this all done at same time ?, put the old arb on to see how much stability the 22mm gives even on a std beam, it's truly unreal.
Old Mar 13, 2010 | 08:33 PM
KSA-Cossie's Avatar
KSA-Cossie
Yup,i love mine too.
Old Mar 13, 2010 | 09:15 PM
105epwr's Avatar
105epwr
Hi mate,no ive not yet put this on i hope to do this next weekend,hope to see even more improvement!
then watch the diff shit its self!!!!
cheers
Old Mar 14, 2010 | 09:03 AM
I'll have to come over and have a gander, post up or pm me how it alters with the 22mm, thanks.
Old Mar 14, 2010 | 09:31 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
so how `special` is the price ?
i have an idea though
Old Mar 14, 2010 | 12:46 PM
Paul_RS's Avatar
Paul_RS
They are roughly £1000
I really need to get mine setup properly, i'll be arsed doing it some year
Old Mar 14, 2010 | 12:55 PM
KSA-Cossie's Avatar
KSA-Cossie
One of the best things you can mod on a cossie imo
Old Mar 14, 2010 | 01:36 PM
shaun_focus4x4's Avatar
shaun_focus4x4
pics?
Old Mar 14, 2010 | 05:09 PM
£1K, why not mod the arms with joints, same result, if you reposition pick ups at same time.
Old Mar 14, 2010 | 05:19 PM
Paul_RS's Avatar
Paul_RS
There a lot of work in the 6 degree beams, the entire arm is altered.
Old Mar 14, 2010 | 07:19 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
thats slightly less than i thought,is there a weight saving too ?
Old Mar 14, 2010 | 07:40 PM
Mike Kerbey's Avatar
Mike Kerbey
good to hear it does the job! one of these beams is on my very long shopping list of bits lol maybe get one in the summer
Old Mar 14, 2010 | 08:03 PM
105epwr's Avatar
105epwr
more than welcome to come over,but will let you no anyway when i fit 22mm bar
cheers
Old Mar 14, 2010 | 08:14 PM
105epwr's Avatar
105epwr
no weight saving,if anything prob slight heavier due to more metal!
theres alot of work involved with the hoop(diff carrier)aswell.
i saw the jigs used to fabricate these up to and theres a few man hrs there...
there doulbled skinned with seam welds to almost factory finish.
when a std beam is sat next to one there is alot of difference,the inner arms are at a complete different angle(more of a straight angle to its mounting point,wheres the std arms curve up to the mounting point,therefore completly changing the pivot point!
all good stuff
Old Mar 14, 2010 | 08:19 PM
It's the pivot point that is the problem, as std it is a semi trailing arm, compression of the suspension creates more camber, but also alters the toe.
Making the mount points parralel , then adjusting arms to suit keeps toe/and or where it is, vastly better than ford did, to be fair though ford had to use the parts bins due to cash constraints.
Old Mar 15, 2010 | 11:24 AM
Mike1's Avatar
Mike1
Makes quite a difference doesn't it! Especially noticable on bumpy roads
Old Mar 15, 2010 | 11:35 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
This explains things :
http://www.randbmotorsport.co.uk/sho...Suspension.pdf
Old Mar 15, 2010 | 04:38 PM
There's also a good book by FRED PUHN, How to make your car handle, me I just leave it Lotus's chassis engineers for ideas!!
Old Mar 16, 2010 | 01:48 PM
-==chunk==-'s Avatar
-==chunk==-
who can set the beams up cos my mate has one in his 3dr but its not set up
Old Mar 16, 2010 | 05:01 PM
Troy from Northampton Motorsport is very good, does all the corner weighting also if you have coilovers, and is very very good.
Old Mar 16, 2010 | 05:51 PM
Mike Rainbird
Caraholic
Anywhere that has a good 4 wheel alignment set up. However, the Cossie is very sensitive to toe changes, so get your mate to PM me with how he intends to use the car and I will give you settings to suit, as it is these that are crucial .
Old Mar 16, 2010 | 07:43 PM
-==chunk==-
harvey fitted the beam a couple of years ago and he took it to a place at newcastle and they made a right arse of it!!! i heard there was a place in harrogate that does all the corner weighting but i forgot what they were called he just uses the car on the road
Old Mar 17, 2010 | 07:47 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
HARROGATE...!! bloody hell man think,i am 5 mins away from there
Old Mar 17, 2010 | 07:10 PM
Mike1's Avatar
Mike1
Powerstation in Cheltenham can also do it but they are probably too far away from you.
Martin ( Budweis ) had his done at Chemix in Stourbridge I believe
3drRich
Sep 13, 2015 07:32 PM
FlashRS
Aug 30, 2015 08:07 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Steve Escos
Aug 24, 2015 07:56 AM
dal3door
Aug 13, 2015 06:55 AM
