brake master cylinder
Old Mar 13, 2010 | 05:18 PM
rich123's Avatar
rich123
Default brake master cylinder
hi all just wonderd is there some way i can get rid of the big bulky brake cylinder,is there a small rally 1 or something i can get to replace it,i need it out of the way for the project im going to do next
thx all
Old Mar 13, 2010 | 05:34 PM
dojj's Avatar
dojj
Resident Wrestling Legend
a car you are going to put it in would help
same as the car you are going to take it out of
Old Mar 13, 2010 | 05:37 PM
rich123's Avatar
rich123
sierra saphire 2.9 v6 t/t
Old Mar 13, 2010 | 05:59 PM
dojj's Avatar
dojj
keep it
just insulate it with about 5 layers of heat wrap, they need it as they get really really hot
Old Mar 13, 2010 | 06:04 PM
rich123's Avatar
rich123
im thinking of doing a single turbo gt40 setup and i dont think i will get the turbo in there with that brake cylinder
Old Mar 13, 2010 | 06:17 PM
dojj's Avatar
dojj
stick with small twins mate, you won't go wrong
the engine doens't rev up enoug to make sue of a super huge turbo, the twins can be small enough to be kept on proper boost from low to high, T25's or, at a push, T28's or thelike would be more than enough
i think i had T2's to make 12-13 psi max and they worked right from idle all the way till about 5500 rpm when the power sort of dropped off a bit
Old Mar 13, 2010 | 06:28 PM
rich123's Avatar
rich123
http://www.youtube.com/watch?v=P7NKw8BHVwc this is why i want to do it same a=engine as mine but its a toataly stock engine with a m/s ecu and bigger injectors and a gt 40 turbo mad
Old Mar 14, 2010 | 09:45 AM
dojj's Avatar
dojj
hooked up really well, but what do the numbers mean?
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
