2wd ex manifold on 4x4
Old Mar 11, 2010 | 03:37 PM
Trist's Avatar
Trist
Default 2wd ex manifold on 4x4
Does it make a difference on a 4x4 to put a 2wd exhaust manifold on. It's a stage 1 4x4. The manifold has cracked so needs replacing
thanks
Old Mar 11, 2010 | 03:41 PM
paul16v's Avatar
paul16v
Monte 087
I would just replace it with an uncracked 4x4 manifold its not a 100% direct swap either and allthough tho 2wd manifold does apparanty flow better then the 4x4 one at stg1 power there is little or no gains to be had from the swap.
Old Mar 11, 2010 | 03:44 PM
As said, use a 4wd one, a 2wd one is a little laggier, due to longer exhuast route, so I'd keep 2wd, might even be changing to a 4wd one myself.
jessie_rs
62
Aug 6, 2019 09:27 PM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
