General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i have a series 2 rs turbo was running fine hasnt been driven on the road yet just start it up now and then to run the engine but now wont start turns over i have a spark but just wont start i have a feeling it might be the ( fuel injection relay) any1 have any ideas what else it could be if you could let me know please!!!!
cheeRS
normally i use to hear a buzzin sort of noise when i use to turn on the ignition but it dont make that same noise any more and i havent checked the plugs recent
cheeRS
cheeRS
That buzzing will be your fuel pump, so either your pink fuel relay under your dash maybe knakered or you need a new fuel pump i'd imagine.
thats wot i was thinking aswell mate thanks for that so once i replace the relay if it still dont work it must be the fuel pump n she will be running fine after that i hope, because i pretty sure my bro could smell the relay like its burnt so i will order 1 from ford tomorrow
cheeRS
cheeRS
