Rattling noise coming from Cam pulley area
Hi all, hope someone can help me with my little problem.
I have an S reg 1.8 zetec petrol (black top i think, correct me if im wrong lol)
i have owned the car for about a month now, and after about a week i could hear a sort of tapping around the cam pulleys. then a week or so later developed into a much louder noise under heavy load, sounded as if a bearing had gone!
a day later the loud noise went away (even under load and on hills) and the normal ticky noise resumed.
Also since first hearing the tapping, i have noticed the power of the car dropping, so much now it can bearly get up a hill in 2nd gear.
Hope someone in this forum will have some knowledge on mondeos, only ever worked on a Seat Ibiza and a 97 megane sport!
Thanks in Advance, Andy
Could be cambelt tensior fooked and its slipped a tooth....
When was the belt/tensioner last replaced? Its very rarely the belt the fails on the zetecs, but the tensioner!
Not too sure, looked through all the paperwork tonight and couldnt find anything related to it, dont think its had a belt change either but its only done 62k but not got a FSH so really unsure haha. Belt does look like it is ok mind
cambelt mate mines doing the exact same noise at the mo if you put your hand on cam cover it even feels like the belt is hitting the cover like its starting to shred apart! im leaving mine tho it only has to last one more week then its getting scrapped anyway lol
worst handling car ive ever owned lol!
yeah thats exactly the feeling lol! belt doesnt look like its on its way out like :S but i guess taking the cover off will let me know for sure! Mine doesnt handle too bad at all, better than my 1.6 r reg megane i had, sticks to the road like glue!
Its very rarely the belt that fails, nearly always the spring in the tensioner goes, so the belt becomes slack then just falls off. Failiure around the 60k mark is quite common, so I would definately get it looked at!
As said nearly alwasy the tensioner that jams, then the rubing belt melts the plastic wheel of the tensioner etc etc till doom!!
If you intend to keep the car and have no history of belt change, and it's worth more than 20p then do the belt and tensioner asap anyway, it's not normal to notice anything out of the normal from belts before they break.
missis scoobie developed what sounded like cover was touching the pulley/belt. I changed belt and pulleys and one of the toothed pulleys cannot be turned by hand,its that fooked. Proper proper lucky!
it could be the cam belt pulley's i'd get them changed including the water pump just for safe sake, esp if you can do it yourself, i'v a 1.8, S reg mondy and i'v got the same noise mine wasn't the cam pulley's though like i thought i changed my belt and it was still there, mine is the aux belt idler pulley, i found this out by spraying the aux belt pulley's with wd40 and the noise stopped, the only difference is my rattle is only on cold start up really and it's quiet under load.
hope this helps a little anyway, and for the record i also think the mondeo's handle well mine usually pisses all over the little boy racers
This may sound silly but just check the pulley bolt is tight.I had this on a civic gti I had.Started off a bit of a rattle and got louder like a knackered tappet.The bolt had worked loose.
thanks for all the replies guys! will hopefully be able to sort this problem! are the cam belt pulleys easy to change? is it do-able without taking off the cylinder head etc?
well you change the tensioner when you change the cambelt. If you are not sure if the head has to come off to do it then I suggest you get it to a garage to be done, as it takes special cam alignment tools etc. Get the timing wrong and it'll kill the engine!
aye! thought so! did train as a mech for about a year, but only learned stuff to do with suspension, and cooling systems and the like! did get to strip and re build a CVH mind
Thanks for all the help guys, unfortunately timing belt went this morning as i went to start it up! was going to the garage as well lol, looking about 700 quid to fix! ahhh the fun
Roosie
Aug 13, 2015 07:40 PM
