Escort Cosworth ABS problem
Old Mar 5, 2010 | 09:03 PM
turbomook's Avatar
turbomook
Default Escort Cosworth ABS problem
Every know and again i get the hazard light and the ABS light on, and then my brake peddel goes rock solid.
Is this likely to be one of the ABS sensors?
Thanks
Old Mar 6, 2010 | 12:15 PM
ECOS95's Avatar
ECOS95
Check the wheel sensors & pickup rings on the CV joint. Mine would come on at 70mph & it was down to some damaged teeth on the OS CV joint.
Old Mar 6, 2010 | 05:53 PM
oldford's Avatar
oldford
I don't think the brake pedal will go rock solid when a wheel sensors fails.
Could be the electric pump on the unit. They are known to fail.
Old Mar 8, 2010 | 04:48 PM
turbomook's Avatar
turbomook
Thanks for the info, it only ever does it every on the very odd occasion
Old Mar 9, 2010 | 01:00 PM
grcossie's Avatar
grcossie
I have had this problem on some Sierra`s, change pressure switch on abs unit, and it works fine
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
James Porter
Aug 26, 2015 10:51 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
