yb rebuild 350bhp advice.
Old Mar 5, 2010 | 06:08 PM
scarnny's Avatar
scarnny
Default yb rebuild 350bhp advice.
hi there people, ive got to a point in my build were i need to get my engine reckoned. i would like to have a pucker engine at the end. need a new turbo t34/ injectors/ pistons/bottom end etc.
ive done some other non turbo engines so im not a total novice, im thinking of doing it myself to save money, how hard can it be?
could anybody shed some light for me like compresion ratios what pistons etc.
would be nice to hear from people who have done one before must be a few of you on here.
cheers andy.........
Old Mar 5, 2010 | 06:11 PM
bad boy rs's Avatar
bad boy rs
standard mahle 4x4 pistons standard rods will be fine mate at that power mate, maybe a bit of head porting but not really needed at that power level
Old Mar 5, 2010 | 06:19 PM
LHD220Turbo's Avatar
LHD220Turbo
if you dont plan on going for silly bhp and stay at stage 3'ish then you dont have to change anything from standard. The only thing id recommend is valve cut outs in the pistons
ECOS95's Avatar
ECOS95
I'm sure at that level its all standard stuff, just bolt on bits to get the power.
Old Mar 5, 2010 | 06:20 PM
LHD220Turbo
ps, the engine is probably one of the easiest to rebuild, its a pinto engine with a turbo on the side
Old Mar 5, 2010 | 06:25 PM
Toe Knee's Avatar
Toe Knee
As said, theres engines on here running over 400bhp now with standard heads on, and as said standrd spec piston wise etc is fine but agree cut outs are a good idea if ur having the engine apart!!
Old Mar 5, 2010 | 06:27 PM
scarnny's Avatar
scarnny
Default rebuild
what cams are best at that bhp. standard ones?
Old Mar 5, 2010 | 06:30 PM
Mike Kerbey's Avatar
Mike Kerbey
As said before, you will be fine with standard internals, cams and head. Just put a better head gasket on with a t34 and some green injectors and ya laughing!
Old Mar 5, 2010 | 06:36 PM
scarnny's Avatar
scarnny
Default rebuild
is it really that easy? would you use an uprated oil pump? and is there any need for better breathing ect.
wheres the best place for parts?
bad boy rs's Avatar
bad boy rs
standard cams mate are fine, .55 t34 and small siemens you'll be flying, dont bother with greens your be bored
Old Mar 5, 2010 | 06:38 PM
bad boy rs's Avatar
bad boy rs
definatly a breather needed on anything over 300, wouldnt bother with an uprated oil pump ive herd mixed views about these
Old Mar 5, 2010 | 06:41 PM
scarnny's Avatar
scarnny
Default rebuild
whats the difference with greens and siemens?
Old Mar 5, 2010 | 06:46 PM
bad boy rs's Avatar
bad boy rs
more power mate
LHD220Turbo
siemens 55lb will flow more; 400bhp ish and they are new and current technology
standard oil pump
a t34.63 with a set of siemens will see a nice and reliable 400hp
Old Mar 5, 2010 | 06:50 PM
bad boy rs's Avatar
bad boy rs
standard oil pump
great set up you'll be smiling gaurenteed
Old Mar 5, 2010 | 07:11 PM
scarnny's Avatar
scarnny
Default rebuild
400 sounds good but i only wanted 350, remember this is going in a mini.
why not the uprated oil pump?
Old Mar 5, 2010 | 07:33 PM
scarnny's Avatar
scarnny
whos the best ford part supplier? Burton power aren't far from me but seem a bit dear.
Old Mar 5, 2010 | 07:38 PM
bad boy rs's Avatar
bad boy rs
ive herd bad things about the high pressure oil pump from burtons, they're ment to fail after not many miles
Old Mar 5, 2010 | 07:41 PM
phil_rs's Avatar
phil_rs
yam yammer
That's gonna be foookin lively in a mini!!!
Old Mar 5, 2010 | 07:46 PM
Twellsie's Avatar
Twellsie
try Matt Lewis or woodford Garage
Old Mar 5, 2010 | 08:00 PM
scarnny's Avatar
scarnny
Default rebuild
thanks for the warning im just after as much advice as possible.
thinking im may be over my head trying to do this.
Old Mar 5, 2010 | 08:11 PM
Twellsie's Avatar
Twellsie
if you have built an engine before, you wont have any problems with a YB and there are so many people on here that have built them to various specs, there will always be someone who can talk you through it
Old Mar 5, 2010 | 08:21 PM
scarnny's Avatar
scarnny
Default rebuilb
yeah cheers, gonna crack on pulling it to bits i think.
Old Mar 5, 2010 | 10:01 PM
scoooby slayer's Avatar
scoooby slayer
my saph had a woodford supplied high pressure pump. iirc 6 bar cold start, 1.8 bar hot idle and 4 - 4.5 bar hot at wot.
Old Mar 6, 2010 | 06:02 AM
scarnny's Avatar
scarnny
has anybody used a burton power high pressure oil pump was thinking about using one myself.ive heard bad things about them.
Old Mar 6, 2010 | 01:00 PM
LHD220Turbo
dont use burton pumps
Old Mar 7, 2010 | 08:47 PM
scarnny's Avatar
scarnny
yeah think ill stay away from burton pumps im gonna keep the engine standard i think. thanks for the advice mate.
Old Mar 7, 2010 | 08:53 PM
Toe Knee's Avatar
Toe Knee
as said just use a standard one, think some people have found the standard pinto pump is exactly the same and u just need to swap the cossie pump cover over as it has the hole in it for the spray bar!! I fitted a 4x4 one to mine as i was advised 2 but sounds like it wasnt really needed!!
Rest is a peice of piss as said if u have worked on an engine before!! its just making sure ur tollerances etc are spot on ie using a plastigauge on the bearings to make sure their clearance is fine etc etc etc
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
RSBryden
Sep 6, 2015 08:39 PM
