ford keylight
You can't get the bulb from Ford, just the whole bit, but you might be able to get it from somewhere like Maplins. I got a new bit a while back with battery and everything and it was about Ł17 if I remember correctly.
yea ive seen them for about Ł10 odd on ebay but obviously a bulb if their availible is cheaper to replace than the whole thing! and tbh never bothered with it on any of my cossies in the past lol, but if i can get a bulb or LED for it cheap enough will probably make the effort!
LED would be much much better, and last indefinitely(almost), easy mod to do, most are between 1.8 and 2.8V so can run direct depending on battery or just a few pence resistor.
I always have a led keyring torch(modded of course!!) on my car keys.
cool, will prob drop down to my local maplins and get an LED as close to the size of the hole for the bulb as poss and try that!! prob wont ever use the fucker after but will look cool
Billy_RS
16
Oct 11, 2025 09:41 PM
borboyous
Aug 22, 2015 11:17 AM
