Snapped cambelt, M reg punto, bent valves??
Old Mar 4, 2010 | 06:26 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Snapped cambelt, M reg punto, bent valves??
Hi lads i bought a punto 3 months ago to drive about in whilst my RST is being restored,
well last night whilst leaving asda the car died, i tried to restart it but it sounded like it had no compression, so whipped the cambelt cover aside and its snapped,
NOW: i have been told 1.1 puntos rarely bend valves? is this true~?
if so i can hopefully bang a belt on and plod on again
Old Mar 4, 2010 | 06:37 PM
daveugc's Avatar
daveugc
yes, they dont bend the valves when the belt snaps
Old Mar 4, 2010 | 06:39 PM
Adam.'s Avatar
Adam.
Back of the net! Thanks mate
Old Mar 4, 2010 | 06:41 PM
H7 CYA's Avatar
H7 CYA
+1
My mate had exactly the same problem...next day new cambelt and was good as gold!
Old Mar 4, 2010 | 06:46 PM
botters's Avatar
botters
competant bodger
8 valves dont 16 valves do
Old Mar 4, 2010 | 06:47 PM
TOMMY_RS's Avatar
TOMMY_RS
SHITE!
sounds like your lucky it hasnt fucked it then lol
good job they dont bend valve's, thats if they dont lol
Old Mar 4, 2010 | 06:49 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Change the waterpump too while you're at it - they like to go at around the same age as the cambelt. Cheap and easy fix.
Adam.'s Avatar
Adam.
Do u mean 8 valve puntos dont or 8 valve cars in general mate
Old Mar 4, 2010 | 06:54 PM
botters's Avatar
botters
competant bodger
8 valve punto's mate not 8 valve cars in general unfortunatly
Old Mar 4, 2010 | 06:56 PM
bythomson's Avatar
bythomson
check autodata to see if its registered as an interference engine
DanW@FastFord
Spelling Club King!
Some 16v engines are 'safe' too.
Old Mar 4, 2010 | 07:07 PM
Adam.'s Avatar
Adam.
Lol with the waterpump takin me the most of ten minutes to change a month ago, and not caring about the motor as its just a banger, i put the old belt back on as it didnt have ANY cracks etc in it, oh well.....lesson learnt
Old Mar 4, 2010 | 07:10 PM
Frenchy0204's Avatar
Frenchy0204
Get to tha choppa!
A little tip for you next time. If you suspect a Cambelt has snapped on a car, then instead of whipping of the Cambelt cover, just take off the oil filler cap, and get someone to crank over the Engine. Providing the Camshafts etc are visible, then they should spin as the Engine turns over.
Old Mar 4, 2010 | 07:12 PM
Adam.'s Avatar
Adam.
Top tip mate my cambelt cover pulls aside tho lol
Old Mar 4, 2010 | 07:14 PM
ryan81's Avatar
ryan81
i snapped my puntos timing belt on the motorway at 70mph , not a thing happened
damn i feel old was my 1st car at 17 (11 years ago cry cry )
Old Mar 4, 2010 | 07:25 PM
DanW@FastFord
Spelling Club King!
...and risk doing more damage to the engine.
Old Mar 4, 2010 | 07:47 PM
Frenchy0204
Get to tha choppa!
Not really. The Valves would already be bent out of the way IF it did already bend them, so you would not be causing anymore damage that it already has.
Old Mar 4, 2010 | 07:51 PM
DanW@FastFord
Spelling Club King!
Agreed, but while there is still a chance of it doing more damage I wouldn't risk it.
Old Mar 4, 2010 | 07:55 PM
Frenchy0204
Get to tha choppa!
I can see where your coming from, and ofcourse, you shouldn't sit there cranking the Engine over and over if you suspect the Cambelt is snapped. Just a quick "blip" of the Starter motor would do it.
Old Mar 4, 2010 | 07:59 PM
DanW@FastFord
Spelling Club King!
Ok, I concede.
Old Mar 4, 2010 | 08:07 PM
sir nose's Avatar
sir nose
useless tip for this engine as there is a steel plate under the cam cover youll see nowt.
i work on these all the time ive been a tech at a fiat garage for ten years never had a fire engine bend valves when cambelt snapped.head gaskets last five minutes though.
Old Mar 4, 2010 | 08:09 PM
Frenchy0204
Get to tha choppa!
I take it you didn't read my post properly then?
Read it again, spring cutter...
Old Mar 4, 2010 | 08:11 PM
DanW@FastFord
Spelling Club King!
Old Mar 4, 2010 | 08:19 PM
sir nose's Avatar
sir nose
am i wrong?
Old Mar 4, 2010 | 08:56 PM
Frenchy0204
Get to tha choppa!
Did I say you was? I said if the Camshafts ARE visible, then you could do it. I wasn't just applying my post to Puntos. But nevermind, your a fiat tech eh? Wow. I better ask you next time then!
Old Mar 4, 2010 | 09:07 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
10 years !!!!!!!!
you pore git
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
gingeRS
17
Oct 2, 2015 09:42 AM
