XR2 racecar with ST170 engine poss build
Old Mar 4, 2010 | 01:56 PM
JasonXR2Racer's Avatar
JasonXR2Racer
Default XR2 racecar with ST170 engine poss build
I'm thinking of building an XR2 racecar with St170 engine and Jenvey throttle body set up and Omex ECU.
What is needed to sucessfuly fit the ST170 engine into the Mk2 Fiesta, I know I need to change flywheel to CVH and sump for a 1.8 Zetec Escort or Fiesta item.
Will be run on BC gearbox
Any info or ideas would be greatly appreciated
CHEERS!!
Old Mar 4, 2010 | 04:36 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
the st170 is basically a blacktop with variable valve timing to give a nice ride on low revs.
just like fitting a blacktop zetec mate
obviously you'll need engine mount modded, loom and ecu, would be simple bolted onto a cvh gearbox though.
Old Mar 6, 2010 | 01:49 PM
xrt-mart's Avatar
xrt-mart
No need to change the sump on the ST170 as its already the right way.
You need to spin the water pump the opposite way though. There are brackets available from area6 that do this off the shelf.
The flywheel can be 1.6/1.8 zetec or a efi CVH if you have one. If fitting CVH the mounting holes need drilling to 11mm which is 0.5mm bigger than normal.
The engine mount needs sorting just the same as any zetec but thats not a problem.
HTH
Mart
jessie_rs
11
Jun 3, 2019 04:57 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Ben26
Aug 27, 2015 08:56 PM
track.focus'd
Aug 12, 2015 05:53 PM
