Cleaning a window with grit stuck on it!?
Old Mar 2, 2010 | 11:05 AM
BM08's Avatar
BM08
Default Cleaning a window with grit stuck on it!?
As title, i noticed the other day when washing the car, on the inside and outside theres a 3" by 3" section of window that feels like sandpaper, not sure what it is but it does move/come off slightly using my finger nail but i cant get it all off properly that way, and ive tried squirting window cleaner onto it and rubbing etc but it just wont shift?
I was thinking clay might work as ive heard it can be used on windows? do you think that would get it off? or any other product i might already have and not thought of?
Old Mar 2, 2010 | 11:29 AM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Yes. Don't forget the lube.
Old Mar 2, 2010 | 11:52 AM
BM08's Avatar
BM08
If you have no knowledge on said subject then why bother posting?
Old Mar 2, 2010 | 11:55 AM
Rick Astley
Yes is the answer to your question, and you use lube to 'lubricate' the clay. This helps prevent the contaminants being scratched against the surface.
If you have no knowledge on the subject or can't even grasp the basic concept I'd advise you not to trouble your pretty little face about it and get your mum to do it for you.
HTH
Tim
P.S Next time I won't bother you plonker!
Old Mar 2, 2010 | 12:13 PM
BM08's Avatar
BM08
HTH
Tim
Most of what i read from you is sarcastic etc, hence thinking you were taking the piss, i do understand what you mean now though, lube as in slightly water down car wash, or straight car wash, or actual clay lube itself.
So yes i do have some knowledge thanks
Old Mar 2, 2010 | 12:28 PM
snOOpy86's Avatar
snOOpy86
carefully with a stanley blade would probably be my choice.
Old Mar 2, 2010 | 12:30 PM
BM08's Avatar
BM08
Yeah but obviously im abit scared of damaging the window if i angle the blade slightly wrong
Old Mar 2, 2010 | 12:38 PM
cossiejsy's Avatar
cossiejsy
If you buy the Autoglym Clay Kit every thing is inside the box as to what you need and also you could try the super resin polish from Autoglym
Old Mar 2, 2010 | 02:06 PM
BM08's Avatar
BM08
Ive got some of that actually but cant really see thats going to shift it, no harm in trying i guess
Old Mar 3, 2010 | 07:48 AM
vaughant's Avatar
vaughant
Tar and glue remover?
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
muz
Sep 30, 2015 08:29 AM
cossie330
Sep 27, 2015 04:13 PM
