Help required from PF plummers
Old Mar 2, 2010 | 06:15 AM
white2lsr's Avatar
white2lsr
Default Help required from PF plummers
Woke up this morning to a cold house and no hot water. Looked at the boiler and there is a light flashing showing it has low presure. This has happened once before and you have to open a tap on the underside of the boiler unit to presumably let more water into the system?? Tried it today though and nothing happened as in you cant feel anything flowing as you open the tap.
Can any plummers advise me as to what this might be before I call someone out.
Cheers for any help.
Old Mar 2, 2010 | 06:48 AM
nellyscossy's Avatar
nellyscossy
is there more than one tap, depending on the loop there may be one on either side of the flexy
Old Mar 2, 2010 | 07:24 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Yes, mine has 2 taps.
How often are you filling it? Maybe indicative of a problem?
Old Mar 2, 2010 | 07:39 AM
Dave Hewy's Avatar
Dave Hewy
Yes, there may be a valve isolating the flushing loop because they can pass and overfill the system. When you fill it take it up to 1.5bar on the gauge. Check all your rads for leaks too as there is a reason why it has lost pressure.
Old Mar 2, 2010 | 05:21 PM
white2lsr's Avatar
white2lsr
This is the 2nd time it has happened in 4 years. last time i just opened the plastic valve and the presure seemed to equalize. This time nothing happens. im cold
Old Mar 2, 2010 | 05:24 PM
Jon(M600BHP)'s Avatar
Jon(M600BHP)
Either you have another valve to open or you have a Non return valve thats possibly jammed
Old Mar 2, 2010 | 06:11 PM
white2lsr's Avatar
white2lsr
Just looked, no taps only this plastic type valve which you can screw in and out. Nothing happens though.
There was supposed to be a Plummer coming round at 6pm but they havnt showed. Just what I need when im filthy from work and cant have a shower.
Old Mar 2, 2010 | 06:13 PM
focusv8's Avatar
focusv8
Picture of said hose?
Old Mar 2, 2010 | 06:19 PM
white2lsr's Avatar
white2lsr
Its not a hose. Its hard piped into the boiler in the housing
dojj's Avatar
dojj
Resident Wrestling Legend
what boiler have you got?
is it just the heating or the hot water that's gone?
is there something else that might have tripped the system so that it's not starting to heat up?
etc?
Old Mar 2, 2010 | 06:24 PM
white2lsr's Avatar
white2lsr
Its a Glow worm 30cxi combi boiler. Needs to see 0.7 bar or it wont run. its sitting at 0.3 bar at the minute.
Old Mar 2, 2010 | 06:53 PM
white2lsr's Avatar
white2lsr
Fixed. Well for now anyways. Didi a bit of research and its a common problem on these boilers. Took the tap off and the bit inside that screws up to seal it off has broken off and it wouldnt let water flow. Need a new tap now.
Old Mar 2, 2010 | 07:10 PM
white2lsr's Avatar
white2lsr
Can anyone recommend a good company to get Glow Worm spares from as ill need a new tap.
Old Mar 2, 2010 | 07:46 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Gloworm!
Old Mar 2, 2010 | 08:00 PM
adsrs1's Avatar
adsrs1
try parts centre part of the wolesey group
Old Mar 2, 2010 | 08:09 PM
tiny2white's Avatar
tiny2white
Originally Posted by Steve the Plumber
Gloworm!
Sod fixing it and throw it away piles of shit!!
wowk
Mar 30, 2021 07:49 PM
20/20 vision
Sep 29, 2015 09:25 PM
