Focus mk1 coilovers
Old Mar 1, 2010 | 05:40 PM
TommyZetec's Avatar
TommyZetec
Default Focus mk1 coilovers
Hi there, is it usual to need the standard top mount for front coilovers ?
My kit came today and they were the only thing i didnt get
cheers
Tom
Old Mar 1, 2010 | 05:57 PM
kevhp171's Avatar
kevhp171
Default coilovers
yes bud thats normal ive bought 2 sets and both times i have had to use my standard top mounts
TommyZetec's Avatar
TommyZetec
thats great to hear, thanks a bunch mate
Old Mar 1, 2010 | 08:22 PM
TommyZetec's Avatar
TommyZetec
Anything I should watch out for when fitting them?.
cheers
Tom
Old Mar 2, 2010 | 12:33 PM
kevhp171's Avatar
kevhp171
Default coilovers
cheers
Tom
you just have to look out for the bottom pinch bolt that holds the strut to the hub mines were rusty and didnt want to come off i had to remove the full strut/hub complete and hit a smaller socket on and use a bit heat to get them off thats the hardest part on the front but if yours are ok then you will be lucky and on the rear i had to use a set of spring clamps to get the spring out and back in but there fairly easy apart from that
hope this helps
jessie_rs
62
Aug 6, 2019 09:27 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
yorkie92
Sep 6, 2015 05:34 PM
