HELP!!!!!!.................
Old Jan 8, 2005 | 07:46 PM
mitchrs's Avatar
mitchrs
Default HELP!!!!!!.................
ok, just going down the road in the rs, all of a sudden a really high pitched squeak started coming from the engine, pulled over, opened the bonnett and it sounded like it was coming from the rocker cover/cam cover or there abouts!!??
also it now wont idle!!
wat the feck is it??!!!!!
please help lads..........
Old Jan 9, 2005 | 11:14 AM
creedy's Avatar
creedy
cam belt snaped?
Old Jan 9, 2005 | 11:26 AM
escort frenzy's Avatar
escort frenzy
See if its got a air leak from the idle screw on the throttle body
Old Jan 9, 2005 | 06:13 PM
mitchrs's Avatar
mitchrs
no its none of the above, it drives, just makes a nice and loud squeling noise and doesnt idle, if i take my foot of the accelerator, it cuts out!!
Help.............................................. .......................please!
Old Jan 9, 2005 | 11:44 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Fan belts ? Sounds silly maybe, but your alternator won't be driven too well at idle and you may not have enough juice to run the engine until you rev it up.
Old Jan 10, 2005 | 09:47 PM
matty872's Avatar
matty872
Could be poss waterpump or cam belt tensioner.
Old Jan 10, 2005 | 10:00 PM
AKRS1's Avatar
AKRS1
i think it sound more like an air leak check all vacumn hoses and also the brake servo
Old Jan 11, 2005 | 05:01 PM
mitchrs's Avatar
mitchrs
Air leak from the inlet manifold
Doh!!
all sorted now though!!
Matt Baxter
46
Jan 15, 2011 01:38 PM
Steve the Plumber
Jul 5, 2010 09:17 PM
RS2000CUSTOM
14
Aug 14, 2008 05:24 PM
