17's onto mk4 escy
Old Jan 8, 2005 | 06:23 PM
Lincolndanny's Avatar
Lincolndanny
Default 17's onto mk4 escy
Hi guys, first post for me
here goes..
do 17's go onto mk4's with no problems, and if not, whats needed-arch lips rolling?and if so what happens about the kit, does it need trimming?
hope someone can shed some light onto the matter, very much looking forward to my stay here
cheers
Danny
Old Jan 9, 2005 | 07:35 PM
MADsteveCOS's Avatar
MADsteveCOS
Default 17's
I got 17's on my old Escort Ok, just had to trim some of the RST bodykit away, and they never rubbed.
Old Jan 10, 2005 | 12:29 PM
CabrioTurbo's Avatar
CabrioTurbo
17's will fit without too much hastle... however the ammount they scrape will depend very much on the ride height and the stiffness of the suspension... if you have a lowered ride height wil knackered standard susp then they will scrape like fook especially at the front...
My car (although a cab) has koni's all round set to hard and has a very low ride height.. this doesnt scrape but some 'modification' was required to the arches for the wheels to fit properly.
The key is how much do you want to lower the car...? if you dont want to lower it you would prob get away without any arch mods.. but it will look like a monster truck..
20-30mm then a little bit of modding is required or just set the suspension to hard and the lack of travel will mean the wheel wont catch the arch.
if you wish to go lower then you WILL have to modify the arch.. either by grinding it away or having it rolled...
which one you choose will depend on
A. how much of the rear arch is there in the first place
B. wether it is easy enough to get the bodykit off and re-fit it after rolling the arches..
CheeRs
Phil
streetracer
Sep 24, 2015 08:14 PM
roomey
Sep 19, 2015 08:40 AM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
chris m1
Sep 7, 2015 08:02 PM
